Headlight Problem
Old Jan 2, 2013 | 02:33 PM
NickStepanov's Avatar
NickStepanov
Question Headlight Problem
Noticed my left headlight went out a couple of days ago and I found water inside of it not much but enough to cause a problem. Water prob got in due to the plastic covering I'm missing above the wheel. Headlight is working again but I was wondering is there a way to dry the inside out without completely taking the whole headlight apart which I prob can't do without baking it..any ideas?
Old Jan 2, 2013 | 02:37 PM
LaoSiFu's Avatar
LaoSiFu
without taking apart and only a little water? I suggest you just remove the headlight, remove all the back piece and let it sit outside to air dry. See if that works or not.
Old Jan 2, 2013 | 02:49 PM
RUNWDVL's Avatar
RUNWDVL
It's usually your ballast is shorted. Probably need to get a new one. Also go get a liner over your wheel.
Old Jan 2, 2013 | 03:50 PM
Spike100's Avatar
Spike100
Since the headlight is now working, it probably did dry-out. However, you probably can expect this to happen again unless you determine what caused the first occurrence. That might mean a disassembly to discover the last “dousing.” If it’s obvious already (you mention noticing something), fix-it so you don’t have the light go out again and to avoid inevitable damage (that always happens when moisture invades a place where it should not be).
--Spike
Old Mar 23, 2013 | 05:56 PM
NickStepanov
Where can I find the wheel covering?
Old Mar 23, 2013 | 06:02 PM
LaoSiFu's Avatar
LaoSiFu
The piece that goes behind the headlight? I have them for sale if interested. Is your an 03-05 headlights?
Old Mar 23, 2013 | 06:04 PM
NickStepanov
Yeah, I have an 07 tho
Old Mar 24, 2013 | 04:22 AM
K51's Avatar
K51
rockauto.com has the fenderliners for a great price. A few months ago I bought a pair for my '08, and they were ~$40 shipped. Not exactly OEM, but you'll never notice the difference, and the fit is perfect.
Uriyo_
Sep 8, 2021 08:46 AM
