NEED HELP ASAP!!! Window wiring diagram plz!!
Old Jan 11, 2013 | 05:46 PM
g3t_t0rk's Avatar
g3t_t0rk
Default NEED HELP ASAP!!! Window wiring diagram plz!!
I pulled the wires out ot the plastic holder. Dont know where to put the wires back. Plz help!! see diagram below.
|10 1|
|11 2|
|12 3|
|x 4
|x 5
|13 6|
|14 7|
|15 8|
|16 9|
Old Jan 11, 2013 | 05:54 PM
g3t_t0rk's Avatar
g3t_t0rk
Sorry if I didn't put the thread in the right place!!
Old Jan 11, 2013 | 08:16 PM
red roadster's Avatar
red roadster
Go to a web site called automotix. You can get online access to wiring diagrams for your year and trim level. Less than 10 bucks for 6mo. access. My access is for a 06 didn't know your year or which side.
Old Jan 12, 2013 | 07:25 AM
g3t_t0rk's Avatar
g3t_t0rk
I need the driver's side window please!!
Old Jan 12, 2013 | 07:34 AM
g3t_t0rk's Avatar
g3t_t0rk
I just bought the Automotix thing. It doesn't help whatsoever.
Old Jan 12, 2013 | 07:38 AM
DavesZ#3's Avatar
DavesZ#3
What year is your Z?
Old Jan 12, 2013 | 07:42 AM
g3t_t0rk's Avatar
g3t_t0rk
Old Jan 12, 2013 | 07:45 AM
DavesZ#3's Avatar
DavesZ#3
Start here..
https://my350z.com/forum/maintenance...anual-fsm.html
they have the wire color codes listed there. Download the proper FSM and look in the GW section to start.
Old Jan 12, 2013 | 07:54 AM
g3t_t0rk's Avatar
g3t_t0rk
Same info as automotix... Page 20...
http://www.nicoclub.com/FSM/350Z/coupe/2003/bl.pdf
Old Jan 12, 2013 | 07:58 AM
KornerCarver's Avatar
KornerCarver
You might need to take your car to a dealer to get your problem resolved. Why did you pull the wires out of the plug?
Old Jan 12, 2013 | 08:02 AM
g3t_t0rk's Avatar
g3t_t0rk
I was trying to do the window motor reset as the windows keep going down after opening my door. After doing some research on the boards, that's what seemed to be the problem. This is the first time I'm working on a Nissan so I didn't know how to remove the plug. I ended up making a bad mistake haha
Old Jan 12, 2013 | 08:11 AM
g3t_t0rk's Avatar
g3t_t0rk
No one can help?
Old Jan 12, 2013 | 08:17 AM
DavesZ#3's Avatar
DavesZ#3
Did you see a chart like the attached one in the GW section? Below it are a bunch of diagnostics steps. Each of them shows one of the connectors and identifies which pin and color for the wires in those connectors. Go through them and fill in the blanks for what you need. You may have to go to a different section to find the references to the door lock related pins.
Old Jan 12, 2013 | 08:31 AM
KornerCarver
Here is a wiring diagram for the power windows. I'm not sure where the plug is that you are talking about. Resetting the windows does not normally require removing any wiring.
Attached Thumbnails NEED HELP ASAP!!! Window wiring diagram plz!!-window-wiring001.jpg
Old Jan 12, 2013 | 09:03 AM
DavesZ#3's Avatar
DavesZ#3
the only problem with that diagram is it doesn't have pin numbers so he won't know where in the connector each ones goes. I assume he removed the wires from the connector that goes to the driver door switch unit since that's the one with the window and lock switches.
Maybe if OP posts a picture that might put us all on the same page (so to speak).
Old Jan 12, 2013 | 02:50 PM
red roadster
On the automix site, on the diagram for my 06, it showed connectors with the numbers of the pins. the connectors were numbered. d7 is the one, I think he has laid out, but his numbering doesnt match the diag. I am guessing that just the way he wrote it out. Any way you can then look at the component which has the corresponding plug number and that shows the pin number with the color code for the wire.
i will be more than happy to convert the plug pins and color code but I only have access to the 06. probably isn't the same. The info he needs is there he just needs to study it a little harder.
Old Jan 13, 2013 | 08:15 AM
drvqz33's Avatar
drvqz33
Is OP talking about the wiring harness?
Because I have both passenger and driver side 03-05 harnesses out of the car and I can take pics of the connectors
Old Jan 13, 2013 | 09:29 AM
DavesZ#3's Avatar
DavesZ#3
That might work, especially if he'd post pics of the connector in question. One slight problem is that the 2003 & 2004 cars has some slightly different wiring than the 2004.5 and later ones.
Old Jan 15, 2013 | 12:05 PM
g3t_t0rk's Avatar
g3t_t0rk
Sorry for the late reply. Here's a pic of the connector
Old Jan 15, 2013 | 02:46 PM
g3t_t0rk's Avatar
g3t_t0rk
Anyone! Haha I'm so close to getting these windows reset!
