2007 engine revs up at cluch press
Old Jan 14, 2013 | 01:43 PM
jerrit1's Avatar
jerrit1
Default 2007 engine revs up at cluch press
While im driving, when I press in the clutch, even if I release the throttle before I press in the clutch, my engine revs up about 200-300 rpms before going down...is this normal, I bought this used 2007 350z with 94k miles about a month ago and it's been doing it since I bought it.
Old Jan 14, 2013 | 02:00 PM
dcains's Avatar
dcains
Not at all. I might look for air/vacuum leaks in the intake system.
Old Jan 14, 2013 | 03:22 PM
SQuaLZ's Avatar
SQuaLZ
Does it do it at idle also? As stated before check for a minor vacuum leak. Also have you checked your alternator? Just a thought maybe extra load on the alternator is affecting your "power"
Old Jan 14, 2013 | 03:26 PM
SQuaLZ's Avatar
SQuaLZ
Also does it do it after the car is fully warmed up or when its cold? When the cars cold it automatically will rev higher when in neutral or on the clutch.
Old Jan 14, 2013 | 03:59 PM
angelo350z's Avatar
angelo350z
That's your car rev-matching.
Old Jan 14, 2013 | 08:33 PM
jerrit1's Avatar
jerrit1
It does not do it at idle.
It does it both when the engine is cold or hot.
I didn't think 2007 had rev matching, can it be disabled?
Old Jan 14, 2013 | 08:47 PM
jerrit1's Avatar
jerrit1
oh, and when I downshift it does not automatically up-rev so this is not the SynchroRev match Nissan put on the 370z in 2009.
Old Jan 14, 2013 | 08:48 PM
Emski's Avatar
Emski
Old Jan 14, 2013 | 08:59 PM
kacz07's Avatar
kacz07
Is your car stock?
Old Jan 14, 2013 | 09:15 PM
jerrit1's Avatar
jerrit1
Originally Posted by kacz07
Is your car stock?
It's not stock....has F5 Fujita CAI, Stillen true duel exhaust, and since I bought it from a used car dealership they and I are not sure what else it may have.
Old Jan 14, 2013 | 09:44 PM
nexlar's Avatar
nexlar
Same question is your car stock??
Old Jan 15, 2013 | 06:49 AM
SQuaLZ's Avatar
SQuaLZ
I have heard of weird issues after installing intakes with people stalling when in neutral and such at highway speed. Maybe the intakes have something to do with his. That would be my guess.
Old Jan 15, 2013 | 04:31 PM
zakmartin's Avatar
zakmartin
I'd be all over the dealership like stink on a turd to get the issue resolved since you just bought it.
Old Jan 15, 2013 | 04:34 PM
rainycityZ's Avatar
rainycityZ
Mine does this too....
2006 350Z Base, 48k, single owner with all paper so I am assuming he took good care of it..
Exact same problem you're describing, step on the clutch and engine revs about 200rpm... Thought it was just something I had to get used to in the Z.
I checked for leaks and didn't find any....
EDIT: Drove car again (cold, ~28F outdoors) and paid really close attention. Car does not "rev-up" when clutch is depressed but rather hangs at that RPM for an extra second or so when cold. After everything is warm with a few minutes of driving, the RPMs drop with depressed clutch. +1 to prior post, get all over that dealer.
Good luck man..
Old Jan 17, 2013 | 01:39 PM
T_K's Avatar
T_K
It's normal. My 2007 has done it since it was new.
Old Jan 17, 2013 | 08:35 PM
dcains's Avatar
dcains
Must be something wrong with my '08, then, because mine has never done it.
Old Jan 18, 2013 | 03:06 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
lmao rev matching
Alexreyes
Sep 30, 2015 11:30 PM
