HELP -- Low Idling
Old Feb 9, 2013 | 09:46 AM
mariar508's Avatar
mariar508
Default HELP -- Low Idling
For the past couple of days my Z has been idling around 500 rpm. I have reset the ECU and attempted to adjust the throttle position using these directions for both - http://www.technosquareinc.com/350reset.htm
However, even after all this it is still idling around 500 rpm!
Does anyone know if there is anything else I can do before bringing it in?
Thanks
Old Feb 9, 2013 | 10:25 AM
tcode's Avatar
tcode
Lift up battery + over the night.
Old Feb 9, 2013 | 10:33 AM
mariar508's Avatar
mariar508
Do you mean to just raise the battery? or disconnect it?
Old Feb 9, 2013 | 10:55 AM
tcode's Avatar
tcode
Disconnect positive pole.
Old Feb 10, 2013 | 03:06 AM
Stolly08's Avatar
Stolly08
i wish i had that problem! try to get rid of a speratic idle between 1200-1800!!
Old Feb 10, 2013 | 06:58 AM
nachospizza's Avatar
nachospizza
Happened to me before it was the going out fuel pump I replaced the whole unit and no more low idle rpm anymore!
Old Feb 10, 2013 | 10:50 AM
mariar508's Avatar
mariar508
Thanks for everyone's input. I will try tcode's advice tonight and let everyone know how that goes. Are there any more suggestions before possibly replacing the fuel pump?
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
