Car went from running great to not starting
Old Feb 17, 2013 | 01:48 PM
ericjackson's Avatar
ericjackson
Default Car went from running great to not starting
Was at an autocross today, everything working fine ans running great. I went to leave and my car wouldnt start. Thought it was weird sice the batt is new, but grabbed someone with jumper cables and that still wouldnt start it. The power seems fine.
The symtoms are just 1 click with the clutch in, i tried it without engaging the clutch just to see if it could be the clutch pedal sensor and it doesnt make the same click.
Here is a video let me know some thingsto check. Thanks
Old Feb 17, 2013 | 02:39 PM
grimm66's Avatar
grimm66
Did you check all the fuses? If they are good try hitting on the starter as it may be stuck.
Old Feb 17, 2013 | 03:47 PM
ericjackson
I havent checked fuses yet because i wasnt sure which ones to look at for this problem.ill try that
Old Feb 17, 2013 | 05:21 PM
ericjackson
Fuses look good. Ill have to jack the car up another night and smack the starter. Is that a common thing.?
Old Feb 17, 2013 | 05:28 PM
oldschool350z's Avatar
oldschool350z
I agree it could be the started I had a similar issue with an impreza. With my luck it needed a whole new started and the tapping on it didn't help start.
Good luck man!
Old Feb 18, 2013 | 02:39 PM
VO...'s Avatar
VO...
Administrator
Sounds like the starter to me. Try push starting it to see if it works just for grins...
Old Feb 18, 2013 | 03:42 PM
Tracktimeplz's Avatar
Tracktimeplz
Agreed, though the Z is rather heavy, so you will need a hill or someone pushing
Old Feb 18, 2013 | 07:03 PM
350z006's Avatar
350z006
can you push/bump start a car with cats?
Old Feb 18, 2013 | 07:06 PM
ericjackson
yes thats how i got home. after bumpstarting it ran fine. but still wouldnt crank when got home
Old Feb 19, 2013 | 10:34 AM
VO...'s Avatar
VO...
Administrator
If your battery is putting out good voltage, your hear that clicking sound, and your car push starts fine...it's the starter.
Old Feb 23, 2013 | 10:06 AM
ericjackson
Quick update. Very easy fix once I had the time to get it off the ground. Was very pleased to see the ground cable had fallen off the starter. Guess I just have to find a nut that fits
350z_z33.
Jul 3, 2017 04:01 AM
pslamp32
Feb 8, 2017 09:07 AM
Katie93
Sep 15, 2015 05:57 PM
350z_z33.
Sep 9, 2015 09:50 PM
