195K Mile 350z Track Multiple Motor Noises - Any help appreciated
Old Feb 20, 2013 | 09:56 AM
Tracktimeplz's Avatar
Tracktimeplz
Originally Posted by Coconut350Track
Well, the motor failed on me this morning. Had just gotten on the interstate, my oil and battery light came on with the engine light flashing, started knocking louder than normal, oil pressure dropped off and it died immediately. Looks like its time for a new motor. It needed one anyways so I'm not completely distraught...
ouch, well, turn this into an opportunity to upgrade, if possible.
Sell your VQ, and swap an LS series, funds permitting
Good luck, keep us updated
Old Feb 20, 2013 | 11:09 AM
Syner's Avatar
Syner
Off topic, but how nicely would an LS fit?
Old Feb 20, 2013 | 11:18 AM
Tracktimeplz
You be the judge
Old Feb 20, 2013 | 12:44 PM
zakmartin's Avatar
zakmartin
I'd run the following tests:
1. Compression test
2. Compression leak down test
3. Vacuum test
4. Pull the valve covers off and inspect everything. Check for play. Check your cams for wear. How dirty is it in there? Replace your valve cover gaskets and put it back together.
5. Your timing chain might be stretched. If you can get to it, check for play.
6. Do a cooling system pressure test and check the coolant for hydrocarbons
The only quick and dirty remedy I'd try is Seafoam. Some people report that ticking/knocking is mitigated or eliminated using that product.
Other than that, like the others said, at almost 200K miles, your engine's a bit of a geezer.
Old Feb 20, 2013 | 03:12 PM
bmyles's Avatar
bmyles
1. Compression test
3. Vacuum test
Guess you didn't read his post....engine is died.
Old Feb 20, 2013 | 03:23 PM
zakmartin's Avatar
zakmartin
Ohhhh... Ouch.
Old Feb 21, 2013 | 02:15 PM
Coconut350Track's Avatar
Coconut350Track
She deserves a new motor so I'm currently shopping for a low-mile vq. How much do you all think I would be able to get out of my old one? Took a video before the car was towed off for motor to be pulled. Sounds great cold when oil pressure is up but once warm it gets pretty noisy. It is about halfway warmed up in this video.
Old Feb 21, 2013 | 02:24 PM
Coconut350Track
Also one other question if I may. I've found a vq35de out of an automatic g35 sedan. Will that drop right in my six speed z or do I need to find one that's been mounted to a six speed?
Old Feb 21, 2013 | 07:10 PM
drvqz33's Avatar
drvqz33
I would try to find a motor from a Z
Just to keep things right
not sure if the motor from the sedan is the same
Chris350z03
Oct 8, 2023 07:19 PM
etkms
Jun 19, 2022 06:30 PM
T'S 350Z
Event Photos
13
Sep 17, 2015 12:55 AM
PureR3d
Sep 10, 2015 06:23 PM
Daniel_dh
Sep 7, 2015 12:56 PM
