dropped RPM during idle
After installing aftermarket clutch and light weight flywheel, i noticed the RPM dropped during idle. It's about 500-400 now. When it gets to about 400, the car shakes as if its about to stall. But then, it bumps back to about 500 and repeat..
i don't think this is caused by light weight flywheel.. Is it either bad MAF sensor or fuel pump?
I cleaned the MAF sensor, and unplugged the battery overnight but didn't help. No unusual lights came up on the dash..
I have the same issue i checked the whole intake and cleaned the Maf with cleaner for it and the same issue, i just recently put a flywheel and clutch in, lightweight 12.8 lbs and stage 3, the rough idle was there before but now its WAY worse, i have to trn the AC on to get it to calm it down, also i have lost about 60 miles per tank...
Mine is still not fixed..
liqalu04
Jan 2, 2022 12:58 PM
