P0420/P0430 after exhaust install
Old Mar 30, 2013 | 09:14 AM
Si2350's Avatar
Si2350
Default P0420/P0430 after exhaust install
I installed invidia gemini cat back along with 60mm invidia test pipes.
After driving the car a few hours my service engine soon light came on, I scanned and i got the codes p0420/p0430 cat inefficiency bank 1/2.
Im assuming this is because of the test pipe install. Do i need 'defoulers' to clear this code?
If so can someone tell me what ones i need to buy?
Old Mar 30, 2013 | 01:25 PM
seymore4's Avatar
seymore4
Professional
You need a tune to make the car actually run right. The ECU is expecting it to have cats and now it doesn't... not going to run right.
Old Mar 30, 2013 | 10:35 PM
Si2350's Avatar
Si2350
Can I not just get 'defoulers' to solve the problem?
Do the downstream 02 sensors affect performance?
Old Mar 31, 2013 | 08:32 AM
seymore4's Avatar
seymore4
Professional
The defoulers trick the O2 sensors into giving a false reading so they don't throw a check engine light, but since the ecu is still expecting the cats to be there the air/fuel ratio will be way off. Only way to correct it is with a tune
Old Mar 31, 2013 | 01:15 PM
Si2350's Avatar
Si2350
Yeah im going to go get the up rev tune here once i finish installing my plenum.
Im going to swap out the test pipes with some hfc as well. its way too loud for my taste.
Old Mar 31, 2013 | 05:45 PM
jes1888's Avatar
jes1888
i have the same problem, only that i have megan HFC's. With the defoulers i still had a PA203 code, and without them i have these ones too, what options do we have for tuning?
Old Mar 31, 2013 | 08:28 PM
seymore4's Avatar
seymore4
Professional
Uprev Osiris is pretty much the only game in town for NA tuning, good thing though its amazing
sales@czp
Sep 23, 2019 03:30 PM
nanotech
Oct 2, 2015 05:02 AM
