Tried finding a vacuum leak today
Old Apr 7, 2013 | 06:15 PM
Marrocco350z's Avatar
Marrocco350z
Default Tried finding a vacuum leak today
Failed miserably
At idle the car sounds like a boiling tea kettle whistling. Sounds like a dying whistling tea kettle when you shut it off. I used some rtv around the rubber gasket on the bottom of the intake manifold and put a clamp on a hose that was missing one on the passenger side valve cover. Still making the noise
Wish I had a FSM but I can't find one for download anywhere.
Old Apr 8, 2013 | 03:37 AM
jv350z's Avatar
jv350z
https://my350z.com/forum/maintenance...anual-fsm.html
Old Apr 8, 2013 | 01:07 PM
KingBaby's Avatar
KingBaby
Hardest Setting
make sure you torque down the manifold good that can cause a leak I think it's 10lbs or something...everything esle you probably haven't touched
Old Apr 8, 2013 | 09:19 PM
Marrocco350z
Does anyone know if this is correct?
Old Apr 8, 2013 | 09:47 PM
Tomek350Z's Avatar
Tomek350Z
Well one way to find a vacuum leak would be to take some throttle body cleaner and spray it in a couple of areas where you think the leak could be. If there is a leak in the area, you will notice the engine RPM increase/change in engine sound. From there you can dig further into the situation. You kind of did this backwards by just taking things apart. Ideally you should have hooked up a scan tool and looked at the live data PID's to see if anything was particularly off.
Old Apr 8, 2013 | 09:49 PM
Tomek350Z's Avatar
Tomek350Z
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
