Transmission:Drain and Fill or Flush?
Old Apr 22, 2013 | 03:46 PM
OneLovelyZee's Avatar
OneLovelyZee
Default Transmission:Drain and Fill or Flush?
Hello,
I just bought a 2004 Z (auto) yesterday with 72,000 miles on the clock. I would like to change the transmission fluid because it doesn't look like the previous owner changed it.
I would like to take it in to get the transmission fluid changed. Should I do a drain and fill or a flush? Does anyone know the number of quarts needed for either of the two services?
Which would be the best AT fluid to use?
Old Apr 22, 2013 | 04:21 PM
DavesZ#3's Avatar
DavesZ#3
Only use the Nissan J-matic in the Z's auto. It takes a little over 9 qts to fill an empty transmission. You won't be able to drain it all, there will still be some left in the case and torque convertor. Manual says to measure amount drained and replace with equal amount.
Find a copy of the FSM online and check out the MA (Maintenance) section. It has the steps and caveats you need to know.
Old Apr 22, 2013 | 06:41 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
I'm anti flush. Usually chit happens
Old Apr 22, 2013 | 06:49 PM
350zchad's Avatar
350zchad
yep, i agree
Old Apr 22, 2013 | 06:52 PM
drvqz33's Avatar
drvqz33
S-matic is the new J-matic. Use only S-matic fluid.
Don't flush. Drain and fill is best. It'll take about 4 to 5 qrts (possibly a little more) for a drain and fill.
Old Apr 22, 2013 | 07:39 PM
OneLovelyZee
Thank you all for the feedback.
How many quarts do I need to take with me for the drain and fill? Should I do the drain and fill once, or drive it around and do it again?
Old Apr 22, 2013 | 07:44 PM
drvqz33's Avatar
drvqz33
Take 6 qrts to be on the safe side.
Drive around and repeat for a more thorough drain
Old Apr 22, 2013 | 07:58 PM
OneLovelyZee
Will do.
I was thinking of having them change my coolant also. How many gallons do I need? Which brand do you recommend?
Thanks.
Old Apr 23, 2013 | 10:36 AM
DFW Z33's Avatar
DFW Z33
I am salad
Originally Posted by OneLovelyZee
Hello,
You should get your clock checked out too, cause Im pretty sure its only supposed to tell you what the time is...
Old Apr 23, 2013 | 01:33 PM
DavesZ#3's Avatar
DavesZ#3
Will do.
Thanks.
There's a section in the owners manual with the capacities listed. It's also in a Sticky thread at the top of this forum. Look for the one about scheduled maintenance.
Just buy a quality name-brand, don't' get a wally-world special. Mix it with distilled water 50/50. IIRC, it takes about 2 gallons of mix to fill after a drain. Again, you won't be able to get it all out of the system so it never takes as much as the true capacity lists.
Old Apr 23, 2013 | 01:50 PM
OneLovelyZee
Thank you for the info! I'm going to get to it.
Old Apr 24, 2013 | 03:00 PM
DarkCreep's Avatar
DarkCreep
omg you are so funny.. -___-
I remember doing a tranny fluid change in an '11 Civic with 50k. My GF's 05 Altima has 100k miles and I want to do it on hers.
I cant remember correctly what I did. I drained the fluid, and refilled with the exact amount that came out. Do I do the same for the Altima with 100k? or do I empty half of the used fluid and refill with new fluid?
Old Apr 24, 2013 | 05:06 PM
350zchad's Avatar
350zchad
just fill slightly less than what is supposed to be added and slowly add till the dipstick reads full, at least that's how i did my Honda E auto... the manual just fill till spills out and stops spilling out
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
tm9293
Oct 29, 2015 02:58 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
350z82
Oct 1, 2015 06:25 PM
SharX59
Sep 27, 2015 09:23 AM
