Engine will not start
Old May 10, 2013 | 10:24 AM
Z33Garage's Avatar
Z33Garage
Default Engine will not start
05 350z Manual. w/ cruise control
Went to put gas and after doing so, car did not start. I could not hear the sound of the starter or starter solenoid. Guy helped me push start the Z and she started on the first try. Drove her home and began thinking.
1: Battery is good (<1 year optima red top)
2: cannot hear starter or solenoid.
3: ASCD clutch switch might be damaged (since pressing clutch (or manually pressing the ASCD button does nothing))
4: The car is not throwing any codes like crank/cam POS sensor issues. ( which can stall the car)
So I am thinking on checking out the ASCD clutch switch before I dig in to the starter.
Any other things I should look into that might be the culprit? And also what started (if mine is damaged, would you all recommend?)
Thanks!
Old May 10, 2013 | 10:42 AM
iideadeyeii's Avatar
iideadeyeii
Bypass the switch to see if it's broken. Then
Bypass the switch to fix the problem.
Old May 10, 2013 | 12:19 PM
Z33Garage's Avatar
Z33Garage
I took the switch off, opened it and it looked clean. Put it back together and the car turned on. When i turned the car off and on again. Same issue and no start. I haven't been able to replicate and turn the car on again. If by bypass you mean connect a with to both wires I did that and car still no start.
Old May 10, 2013 | 04:39 PM
Z33Garage's Avatar
Z33Garage
I don't think starters like amsoil...
Uploaded with ImageShack.us
Old May 10, 2013 | 09:57 PM
shermcs's Avatar
shermcs
That is an expensive anti-rust agent!
Old May 11, 2013 | 07:58 AM
Z33Garage's Avatar
Z33Garage
^ ha!
Yeah it is. I basically washed it with electronic cleaner and I cleaned up the other end connector, and left it to dry. I will be picking up a multimeter and test probe light today to continue testing...
Old May 13, 2013 | 06:52 AM
Z33Garage's Avatar
Z33Garage
Good news everyone.
After prodding around, I found that the clutch switch was actually good. Good voltage readout at the starter relay + power cables. Seems the relay on the starter was fawked, as well as the internals. ( I took the starter apart and its seen better days, too much oil + carbon + dirt pitted the insides)
So I broke out my welder and my crappy welding skills and fabbed this shield from some metal I had laying around + sprayed some left over engine enamel.
Does the job, shields the starter from oil or leaks from above.
^ my crappy weld job :/
^ test fit
^paint
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
