Water in headlights
Old May 12, 2013 | 04:21 PM
marines z's Avatar
marines z
Default Water in headlights
I wash my z today and know twice I put water in my head light. I think my foggy was in that head light is from the water. How could I restore the inside of them.
Old May 12, 2013 | 05:13 PM
mattleegee's Avatar
mattleegee
dry it out?
you have wheel well splash guards installed?
Old May 12, 2013 | 05:27 PM
marines z's Avatar
marines z
Originally Posted by mattleegee
dry it out?
Yes it is installed and there is nothing wrong with with them
Old May 12, 2013 | 05:53 PM
mr. sparco's Avatar
mr. sparco
Take off headlights and reseal the outer lens with OEM sealant tape. If you don't want to use oem you can buy butyl rubber sealant which is essentially the same thing but costs less.
Old May 12, 2013 | 10:04 PM
marines z's Avatar
marines z
Unhappy
The question was if the discoloring is in side the head light how would I restore it so its clear. Would I do it the same as the out side just on the inside?
Old May 12, 2013 | 10:09 PM
Bmurray350z's Avatar
Bmurray350z
wtf. post a picture
Old May 13, 2013 | 03:11 PM
mr. sparco's Avatar
mr. sparco
So pull the lens off, clean it up, buy the sealant I posted and put it all back together. If the actual lens plastic is yellowing or fogged then you're SOL. However, it's almost always just the surface of the lens (either inside or out) that needs to be buffed/polished. If you need DIY directions do a search here or on google for headlight restoration.
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
350z82
Oct 1, 2015 06:25 PM
JGee450
Sep 30, 2015 04:32 AM
