Climate control question
Old May 24, 2013 | 01:18 PM
RawrXTC's Avatar
RawrXTC
Default Climate control question
So, I just got my Z not that long ago and I noticed that when I have the air on and the *** is at 60 degrees cool air comes out which makes sense. Then if I was to move it ONE notch up from 60 which should be in the low 60's still I believe, the air starts coming out really warm. I mean one notch from 60 degree should be around 63 or so right? The air that comes out is pretty warm, warm enough so that after a few minutes I gotta turn it off or put it back to 60 again.
Does anyone else have that problem? Is it supposed to be like that or is something wrong?
P.S. I have a 2006 if that helps
Old May 26, 2013 | 05:09 PM
RawrXTC's Avatar
RawrXTC
No one at all?
Old May 27, 2013 | 10:36 PM
amr_electron's Avatar
amr_electron
Didn't drive my car since a very long time, But iirc, It shouldn't blow warm air if you move the **** one notch up.
Most likely it's the AC switches or the ribbon cable, Did you remove or install a head-unit recently ?!!!
Old May 28, 2013 | 10:36 AM
RawrXTC's Avatar
RawrXTC
No, I haven't removed or installed anything that could affect it. I was thinking it could be the ribbon as well. I searched and saw that two other people had the same problem and no answer as well. -_- I'm probably going to check the ribbon when the weather isn't so crappy.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
