2003 Touring Knock Sensor Question
Old Jun 8, 2013 | 01:02 PM
JDM_35OZ's Avatar
JDM_35OZ
Default 2003 Touring Knock Sensor Question
Hey guys, my car has been throwing the P0327 or whatever it is knock sensor code. I've been looking at threads and just wanted to make sure on a couple of things.
My Z has been feeling sluggish in the past couple of months, so I think the knock sensor harness might be bad too.
The question I have is if I get a new knock sensor and sub harness, would that solve my problem?
Is the wiring harness different from the sub harness for the knock sensor?
Thanks!
Old Jun 8, 2013 | 05:32 PM
kelly350Z's Avatar
kelly350Z
I changed both at the same time last year and fully resolved the sluggishness. I didn't want to have to tear everything apart twice in case it was the sensor and/or the harness.
I ended up replacing the fuel injector harness which came with the little sub harness that hooks up to the sensor.
Old Jun 9, 2013 | 11:01 AM
lalom's Avatar
lalom
i had the same problem and decided to only change the sensor since i couldn't find a new harness for it. car still hesitates when i get on it so i'm thinking i might have to get a new harness or maybe something else is causing this problem!
Old Jun 9, 2013 | 12:23 PM
JDM_35OZ's Avatar
JDM_35OZ
Sweet thanks for the info! So I should just get a new knock sesnor and a new sub harness correct?
Old Jun 9, 2013 | 07:40 PM
kelly350Z's Avatar
kelly350Z
You might as well change both at the same time and save yourself the chance of not having the problem fixed and them have to take everything apart once more.
Siqcology
Sep 18, 2019 01:45 PM
Vigman
Nov 17, 2015 04:34 AM
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
FromGtoZ
Sep 20, 2015 03:41 PM
RWDBajan
Sep 8, 2015 06:25 AM
