Rear Caliper Removal Help
Old Jun 24, 2013 | 12:03 PM
ambushphoto's Avatar
ambushphoto
Default Rear Caliper Removal Help
Hey guys,
Im trying to replace my rear rotors and I'm having a tough time getting the caliper bolts off. My car is an 03 and it looks like the brake rotors haven't been replaced in a long time. I live in Canada and the car has been winter driven, so everything is pretty rusty. I've hit it with enough liquid wrench to sink a ship already.
I cannot get enough torque on any of the 4 caliper bolts (2x 14mm and 2x19mm) to get them to break loose. I cant get a big enough breaker bar on them and the area is too tight to get an impact wrench on any of the bolts.
Does anyone have any advice about getting a better angle on the bolts? I am willing to remove suspension parts since I am doing a coilover/camber arm install as well.
Thanks.
Old Jun 24, 2013 | 12:52 PM
Syner's Avatar
Syner
Slip a pipe over your breaker bar. That should give you enough leverage.
Old Jun 24, 2013 | 12:57 PM
beezee's Avatar
beezee
did you let it sit long enough after the liquid wrench?. PB Blaster has worked for me in the past. A day before I start the install I spray it in so it sits overnight.
Old Jun 24, 2013 | 01:01 PM
bealljk's Avatar
bealljk
PB Blaster for sure…spray it every hour and let it sit…obviously it's well-rusted on...
Old Jun 24, 2013 | 06:24 PM
ambushphoto
Thx for the replies. I can't get a pipe on my breaker bar since there isnt physically enough room to even get my breaker bar on the bolts. I did manage to break free the top 14mm and the top 19mm nuts but i can't even get a breaker bar on the bottom two nuts. One of the suspension arms is in the way. About all I can do is get a 14mm box wrench on it which is not nearly enough torque. I can't get the arm off either, no room for tools again.
Old Jun 28, 2013 | 03:52 PM
Kunihiro's Avatar
Kunihiro
When I get a nut or a bolt that's really on there (and there is little or no room for a breaker bar), I spray the heck out of it with lubricant. Then, I'll take a wrench that I don't really care about, place it onto the nut or bolt and then whack it with a rubber mallet or a regular hammer in the approrpriate "release" direction. That generally solves my problem.
Remember, righty tighty, lefty loosey.....
3vilbunny
Jul 18, 2017 05:10 PM
