Hey guys, I have had my car since February of 2012 and since then I have had to change 3 wheel bearings. The driver side and axle right when I bought it, the in March of 2013 I had to change the passenger wheel bearing, now I need another passenger wheel bearing! Is there something that is killing these things?
I'm on hotkiss springs with the springmount cut mod.
20" rims are putting more stress on everything in your suspension. On your car it's manifesting as the wheel bearings. Get rid of the wheels and I bet your problems will go away.
If you still havn't got your alignment issue resolved then I'm betting thats it. You are running 10x the total toe according to factory specs. Get it fixed if you havnt or as you can see, youll be replacing many things.
I got my alignment fixed by using more camber since the Toe bolt was frozen on there. I am bringing it back to the place that installed the wheel bearing in march since it has a 1 year warranty.
Well if you are using large amounts of camber to make up for your crappy toe, then theres another reason theyre probably dying. Take your car somewhere else seriously.
