Leaking Oil?
Old Jul 18, 2013 | 02:00 PM
04_Touring's Avatar
04_Touring
Default Leaking Oil?
I have had my 04 Z since march. I have put a little over 3k miles on it(currently has 46k). Recently I have not been driving it as much. The last time I drove it was on sunday. So a little over 4 days ago. Today I decided to take it out for a spin(just a mile or two up the street). When I returned I parked about 20 yards closer to my house so that I could wash it. Once I finish washing I noticed there was a small puddle of what smelled and looked like oil. My question is; did this occur from my car sitting, not letting my car warm up or am I just leaking oil. I did check my oil level and it is high. Car runs fine and it takes synthetic.
Same puddle just different angle, showing the oil
Old Jul 18, 2013 | 05:37 PM
Touge Z's Avatar
Touge Z
maybe the drain bolt came loose from vibration or needs a new crush washer?
Old Jul 18, 2013 | 08:29 PM
bealljk's Avatar
bealljk
OP, in your last / oil pan & plug picture - is that a crush washer on the plug? would you say the oil is coming from the drain plug area?
I would remove that during your next oil change - either put a fresh crush washer back on or just use the plug and tighten it down to factory specs (I believe is 22-28ft*lbs of torque) and see what it does.
Old Jul 19, 2013 | 11:52 AM
04_Touring's Avatar
04_Touring
took it to a mechanic who is a friend. He said the washer was not the right size(it was too large). So the dealership I bought it from must have ****d that up. All is good now
Old Jul 24, 2013 | 01:44 AM
99 percent of the time the correct answer is the most obvious answer.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
