P0301, plug was fouled
Old Aug 4, 2013 | 09:57 AM
will_z32's Avatar
will_z32
Default P0301, plug was fouled
Pulled this code a week ago. just now got the time to pull the plug and coil and start looking. The plug was fouled when i pulled it. Went and bought a new one, put it in and started. All codes were cleared. ran fine for three minutes then started missing again. Haven't pulled the codes yet again, since i don't have a reader. should have one in a few hours. Anyways, pulled out the new plug and of course it smelled of unburnt fuel... Any ideas where to go now. Also i changed the plugs about 15000 miles ago, which was about two years ago. need any other info just ask.
Old Aug 4, 2013 | 10:32 AM
0jiggy0's Avatar
0jiggy0
Need a ton more info. Mileage on car. Run a compression test. Swap the injector on that cylinder with another and see if the issue moves to another cylinder or stays.
Old Aug 4, 2013 | 12:11 PM
will_z32's Avatar
will_z32
Mileage is 101,XXX. Planned on doing compression test tomorrow when i have time. Anything else to try while i am doing this.
Old Aug 4, 2013 | 12:41 PM
0jiggy0's Avatar
0jiggy0
Can also swap the coil. Make sure its a different one from the injector to isolate the problem.
Old Aug 4, 2013 | 02:47 PM
Italianjoe1's Avatar
Italianjoe1
Most likely a bad coil, super common problem
Old Aug 4, 2013 | 04:50 PM
Touge Z's Avatar
Touge Z
bad coilpack. very common especially around your mileage.
Old Aug 5, 2013 | 01:02 PM
will_z32's Avatar
will_z32
nah, its not the coilpack. i forgot to mention that i had already switched it around with cylinder 3 coilpack and the problem did not move.
burglapfd
Dec 6, 2020 01:04 PM
350z82
Oct 1, 2015 06:25 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
35reilly
Sep 28, 2015 07:42 AM
