Hows it going guys got an 04 350z and i keep getting the code p1283 bank 1 sensor 2 lean. The code will come on when it wants sometimes with in 500+ miles sometimes with in 50 miles. The code will also shut off on its own with in a few days or so. The car is tuned on up rev with injen cold air intake, motordyne test pipes and full motordyne exhaust, motordyne iso thermal 5/16 spacer. I also have a wide band in the car on normal driving it is around 13.8-14.2 and when WOT is around 12.8-13.2 car feels like it has no loss of power what so ever. Going to check to see if 02 sensor is good this weekend but will like to get anymore input on what i maybe should check for. Thank you
Pretty sure that code is associated with the removed cats. Have your tuner block out the code via UpRev and you'll be fine. I have had that code on both my previous and current Z due to removing the cats..
