Car dies on the highway!
Old Aug 30, 2013 | 05:23 AM
jc_crump's Avatar
jc_crump
Default Car dies on the highway!
Hello, whenever i am on the highway going about 70 and shift my car in to neutral or put the clutch in the car dies. I can go about 80 when the AC is on but still the same happens. I have no clue what it could be. My check engine light comes on and off for Bank 2 Cat below threshold. Any help would be greatly appreciated.
Old Aug 30, 2013 | 05:37 AM
SQuaLZ's Avatar
SQuaLZ
Any mods?
I have heard of this issue before with people that have intakes.
If all stock my guess is the 02 sensor is going or gone. That sensor reads the air/fuel and adjusts accordingly. So if you are getting that CEL and the car is stalling, maybe it is time to change the sensor.
Old Aug 30, 2013 | 06:04 AM
jc_crump's Avatar
jc_crump
Originally Posted by SQuaLZ
Any mods?
Yes I have a intake installed on it. But why would that cause it to stall if the air is regulated by the throttle body?
Old Aug 30, 2013 | 06:32 AM
YardieXplorer's Avatar
YardieXplorer
Any mods?
Yes that is correct.. I have a pop charger and it damn near scared me when throwing it in neutral at around 80 approaching a corner.
Did you reset your ecu after installing that intake especially if you had disconnected the MAF sensor?
Old Aug 30, 2013 | 08:41 AM
jc_crump's Avatar
jc_crump
I reset the ecu multiple times. Did that fix the problem with your pop charger?
Old Aug 30, 2013 | 10:31 AM
KornerCarver's Avatar
KornerCarver
Why would you put the car in neutral when approaching a corner at 80 mph? The car is much more controllable with the car in gear.
Old Sep 2, 2013 | 08:52 AM
YardieXplorer
Not a steep corner.. Just a slight bend at the end of a bridge where a stop light eventually comes up.. Had ample time.. I usually just coast down to the slight..But having a car shut off and you lose power steering at any speed would be a bit nerve racking.
And maybe that time i was down to 50-60
etkms
Jun 19, 2022 06:30 PM
kyin
Sep 29, 2015 06:57 AM
VQA33
Wheels Tires
Sep 8, 2015 08:30 PM
