having a big issue
Old Sep 7, 2013 | 04:09 PM
Marc Crowley's Avatar
Marc Crowley
Unhappy having a big issue
2006 350z pop charger/cat delete
so i this morning i tried to start my car didnt start figure it was the battery cause of the new amp i installed so i jumped the batter and when i went to start the car it idled like total crap sounded like hell.. when id give it gas it dies out making a weird hissing noise. my car port stank of gas while it was doing this.
i got the P0300 code along with a couple others P0130 and the typical cel light
p0429 p430.
im not 100% what the deal is the car is well maintained.
i unplugged the MAF to see if that was the issue it idled fine after i pulled it but once i wiped the codes out and tried to start the car it wont turn over all i get is a weird clicking a sound from somthing electronic in the car.
the amps unplugged and i tried to jump the car again still wont turn over..
has anyone had this or similar issue?
also i had a weird reading for the scanner saying the input voltage was to high or somthing like that not 100% was too pissed off to really care
Old Sep 7, 2013 | 05:46 PM
AshMan's Avatar
AshMan
Club Moderator
the Hot Spot
Have you had the battery tested? you might have lost a cell. Something is definitely up with the battery.
Old Sep 7, 2013 | 06:14 PM
Marc Crowley
im sure the battery is dead its been in the car 9 months and went threw a hell of a winter in kentucky and with the temps changing here in pa its gonna need to be replaced..i plan to replace it tomorrow but the only weird part was it wouldnt turn over even with another vehicle jumping it
Old Sep 7, 2013 | 07:53 PM
DaveJackson's Avatar
DaveJackson
Master
^Normal. Replace battery and go from there with any other problems.
(LoL at "brutal Kentucky winter"!)
Old Sep 8, 2013 | 05:50 AM
djamps's Avatar
djamps
I'm guessing water leaked in thru the main harness boot over the ECU directly behind the battery, given you probably routed your amp wiring thru it...
Old Sep 9, 2013 | 02:47 AM
Marc Crowley
ummm no.. its garage kept sooo i dont think rain has anything to due with my engine misfiring..
Old Sep 9, 2013 | 02:49 AM
Marc Crowley
yeap....changed the battery but doesnt help with the error codes so..yeah
Old Sep 9, 2013 | 09:40 AM
Marc Crowley
so ive come to the decision its not wet wiring harness like stated above but the battery was bad and i did lose a cell. i got the car going and i pulled the MAF sensor and it went into safe mode idling normal but a but a bit blurpy meaning its a bad MAF sensor.. hopefully a correct replacement will do the trick. and nothing is seriously wrong.. i had a feeling the maf was going out a month ago it starting throttling funny and idle a bit diffrent so kinda had a feeling it was on its way out.
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
