Burning Smell on HARD accelerations?
Old Oct 21, 2013 | 05:25 PM
Bdizz777's Avatar
Bdizz777
Default Burning Smell on HARD accelerations?
Ok so the few times ive actually WOT past 5k i get a weird burning smell like hot exhaust/oil smell for like a few seconds then goes away when i get back to normal speeds. The clutch engages fine, shifts fine, not slipping, accelerates great.... I read around and theres like a million different things about what it could be.
It has 32k miles on it. Only thing i can think of is the exhaust is just dumping cuz of WOT and CATS are getting hot causing the smell since they are right under the seats. I know what a bad clutch smell and buring oil smells like and its only on HARD accelerations. Thanks!
Old Oct 21, 2013 | 06:34 PM
DayZblue350Z's Avatar
DayZblue350Z
my 04 burns oil when i do a cold start and then get on it in the first 5 minutes or so. make sure its warmed up and watch your oil pressure gauge.
Old Oct 21, 2013 | 06:52 PM
calidrew909's Avatar
calidrew909
warm up your car
Old Oct 21, 2013 | 07:03 PM
Bdizz777's Avatar
Bdizz777
Originally Posted by calidrew909
warm up your car
This is when the car is fully warm like sitting in traffic, driving normally like 20-25 minutes after its warm. The oil gauge reads bout 20-25 at idle like it should
Old Oct 21, 2013 | 08:50 PM
Waiz's Avatar
Waiz
Do you have OEM Cats? What year is your Z?
I have a feeling you might be burning oil otherwise and you're just making your situation worse by going WOT all the time
Old Oct 21, 2013 | 08:56 PM
kacz07's Avatar
kacz07
Spilled oil on the motor?
Old Oct 21, 2013 | 09:17 PM
Bdizz777's Avatar
Bdizz777
Bought the car 2 weeks ago from my dealer oil was changed there and i detailed the car b4 i bought it so i pressure washed and degreased the motor after the safety inspection.
Yes the exhaust is stock still only 32k miles and its a 2004. My buddy at work has a 2003 and he said to keep an eye on the oil gauge and from what hes seen and ive told him said doesnt sound like its burning oil....but i really cant afford anything with the engine even tho i have a 3 year warranty when i bought it. I dont have any residue or dark smoke coming from the exhaust either.
Old Oct 21, 2013 | 10:24 PM
Bdizz777's Avatar
Bdizz777
Went out to my car to look at some stuff and popped the hood real quick. Oil level is spot on still, golden fresh color, no leaks or signs of oil leaks in car or on ground, muffler tips are shiney no residue...
Only other thing is the exhaust heating up at WOT or clutch burning but the clutch is deff NOT slipping or feeling sloppy at all only has 32k and i know what a shitty clutch feels like my other car has 120k on stock clutch and i beat it more than the Z.
Old Oct 22, 2013 | 01:13 AM
superstuddc27's Avatar
superstuddc27
It depends on what the smell is. Probably not oil since you said you checked it. Only so many things that can burn. If it's rubber, you'll know what that smells like. Check tires obviously. Check your ebrake and make sure you're not engaged or it's not completely disengaged. Check brake pads.
Get out of the car immediately after and sniff around to see where its coming from. Physical location will help you figure it out at least to narrow it down.
Take a laser temp reader and shoot the cat and you'll see if it's busted. but if the cat's busted soon enough your CEL will come on. And you would know because it would smell more like fuel and smog than something burning.
Old Oct 22, 2013 | 04:38 AM
samsniss350z's Avatar
samsniss350z
My old S14 when driven at reasonable speeds was fine but when I stepped on it I got a weird burning smell that smelt oily and it was only when I went round it and felt heat coming from the front N/S hub that I realised that I had a worn wheel bearing. I couldn't feel it through the steering wheel, even when turning left I couldn't feel any grinding. Its probably unrelated but perhaps just worth checking.
Old Oct 22, 2013 | 06:29 AM
crsracing19's Avatar
crsracing19
dont mean to be thread jacker but i get the same thing. Would test pipes cause this more.
Old Oct 22, 2013 | 06:38 AM
JERZ350's Avatar
JERZ350
If you're not losing any oil, then I'm pretty sure that's normal. A lot of cars leave a scent in and out of the cabin when you go WOT or even climb very steep inclines over an extended period of time, even brand new cars.
Old Oct 22, 2013 | 09:12 AM
Castor771's Avatar
Castor771
I had a rotten egg smell triggered only when I revved my engine beyond 3k rpms. I took it to the dealer and they recommended the fuel decarb service which involves cleaning the fuel injectors, throttle body and adding fuel additives. Was skeptical at first but decided to give it a try. I haven't had the smell since the fuel decarb service. I have a 08 with 25K miles.
Old Oct 22, 2013 | 09:14 AM
Castor771's Avatar
Castor771
I purchased it used and it's likely the prior owners used it mostly for city driving as I do the same. The service dept explained that the fuel isn't getting burned out completely due to the stop and go traffic.
I doubt it's the cats since your mileage is so low. Our cats are usually good for about 100k from what the service dept told me.
Old Oct 22, 2013 | 03:49 PM
Bdizz777's Avatar
Bdizz777
It does it alot of times goin up hill. My other car does the same thing up hill too has a weird smell when goin up an incline. Everything is checking out ok as far as what everybody is sayin to look at or check. It does shake around 80mph+ tho slight shake nothing crazy tho.
Old Apr 11, 2015 | 11:31 AM
Castor771's Avatar
Castor771
Revisiting this. My service engine soon light came on within the past two weeks. Today, I went to another dealership that performs diagnostics on weekends and they determined the catalytic converters are bad. Fortunately, they are under warranty 8 year/100K miles. The 2008 Z has about 29,500 miles. So glad the rotten egg smell mystery is solved. It's been doing it for about 2 years. I just couldn't prove they were bad. It even passed smog last year. lol
lapham3
Oct 7, 2022 03:15 PM
etkms
Jun 19, 2022 06:30 PM
apex locator
Jul 23, 2021 02:27 AM
3vilbunny
Jul 18, 2017 05:10 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
