Rear end issues!
Old Dec 29, 2013 | 04:17 PM
350zChick13's Avatar
350zChick13
Exclamation Rear end issues!
So this other day I was leaving work all was fine. Mid turn the whole rear end starts hopping almost like driving with a welded diff which I don't have. I have 4.08 gears in it and I have never had a problem. Now the car will move front and back but turning is next to impossible. I have a few ideas of what it could be but confirmation would help greatly before I start dishing out money. All help is much appreciated!! Thanks
Old Dec 29, 2013 | 04:50 PM
myfirstzcar's Avatar
myfirstzcar
Stock diff? Is it a stock lsd or clutch type? Got oil in it? try jacking it up and moving things around.
Old Dec 29, 2013 | 05:39 PM
350zChick13
It has a stock vlsd with upgraded gearing. I've been working so much I haven't had time to jack it up. What would I be looking for specifically when I do this?
Old Dec 29, 2013 | 07:19 PM
350zjason350z's Avatar
350zjason350z
Know it all
Was it installed correctly the back lash could not be right ...
Old Dec 29, 2013 | 11:01 PM
350zChick13
It was installed perfect as I know of. The car has ran fine since they were installed in 2010.
Old Dec 30, 2013 | 11:36 AM
myfirstzcar
Jack up one side at a time and turn the wheel. It should turn hard, but smoothly. If it doesn't turn or turns part way then locks up, you may have a diff issue. Make sure the car is in gear when you check the diff.
Pleask
Dec 21, 2021 03:17 PM
pr_350z
Oct 1, 2015 05:03 PM
Depravity
Oct 1, 2015 04:49 PM
samansharif
Sep 25, 2015 12:31 PM
