Quick help with anti freeze
Old Jan 20, 2014 | 08:30 PM
zetosan's Avatar
zetosan
Default Quick help with anti freeze
Well something was wrong with my cooling system, I suspected that it was the thermostat but I wasn't entirely sure. So I changed the thermostat today, flushed the system about 4 times and put in a extended life prestone coolant. Now the question, is the prestone anti freeze going to five me problems in the long run? Should I change it to another coolant? If so what's recommended? I have done plenty of research , half the people stated prestone is okay and half stated no. What should I do? The car is a 2005 has about 74000 miles. Thank you and any help/advise is highly appreciated
Old Jan 20, 2014 | 09:29 PM
Syner's Avatar
Syner
Please tell me you mixed/bought premix.
Brand-wise, I've never been picky with coolant. You should be fine with whatever you choose.
Old Jan 20, 2014 | 09:37 PM
zetosan's Avatar
zetosan
I mixed it 50/50 maybe 40/60, I live in SoCal, so I added a little bit more distilled water.
Oh alright, because I've been doing a lot of reading and saw all these people with messed up radiator or water pump caused by using wrong anti freeze supposedly according to them.
Old Jan 20, 2014 | 09:52 PM
Syner's Avatar
Syner
50/50 or 40/60 is good.
I've seen the debates, but have never seen any factual/objective proof posted in regard to new coolants.
Older, consumer coolants had higher concentrations of uninhibited ethylene glycol which is where the comparisons likely stem from (increased uninhibited content increases corrosion). Uninhibited worked well, except it broke down quickly under high heat - the products of the breakdown were the cause of corrosion.
Old Jan 20, 2014 | 11:20 PM
Prestone is good. You will be fine. I assume that the container says "for aluminum block motors."
Old Jan 21, 2014 | 12:24 AM
myfirstzcar's Avatar
myfirstzcar
Most, if not all modern coolant is safe to use.
Old school coolant, when mixed with some types of factory coolant, has been known to cause issues, but you flushed it out good so no worries.
Old Jan 21, 2014 | 03:24 AM
travlee's Avatar
travlee
Master
back in the day (which was a thursday btw) if you mixed green and orange coolant together it would gel up, i think that now they make them where they dont do that anymore
Old Jan 21, 2014 | 05:54 AM
zetosan's Avatar
zetosan
Well it says it's compatible with all engine cooling system including aluminum haha so i think it is!
Old Jan 21, 2014 | 06:15 AM
Syner's Avatar
Syner
All new, consumer coolants have corrosion inhibitors. You'll be fine.
Old Jan 21, 2014 | 06:17 AM
travlee's Avatar
travlee
Master
syner are you okay.... did you get hit upside the head with the nice bag?
Old Jan 21, 2014 | 06:21 AM
Syner's Avatar
Syner
My hormones are mellowed out - I got laid 2 nights in a row.
Old Jan 21, 2014 | 06:50 AM
travlee's Avatar
travlee
Master
haha, explains alot.
Old Jan 21, 2014 | 12:53 PM
myfirstzcar
+1 to Travlee and Syner. Anything that says safe for aluminum engines is just plain redundant.....it's all safe for aluminum.
Old Jan 21, 2014 | 02:36 PM
zetosan's Avatar
zetosan
Thank you all for the replies!!!!!
Old Jan 21, 2014 | 06:09 PM
TuckerE36's Avatar
TuckerE36
Hahahaha I've even noticed Syner being nicer than usual!
Old Jan 21, 2014 | 06:16 PM
Syner's Avatar
Syner
Damn it! You too?
Maybe something is wrong with me...
Old Jan 22, 2014 | 01:50 AM
travlee's Avatar
travlee
Master
Damn it! You too?
weeeeeeeeell, we didnt want to say anything, i think you lost your sarcasm with your load.
Old Jan 22, 2014 | 06:51 AM
Syner's Avatar
Syner
weeeeeeeeell, we didnt want to say anything, i think you lost your sarcasm with your 2 loads.
fikst
The "2" is very important.
lapham3
Oct 7, 2022 03:15 PM
350Z_Al
Oct 29, 2020 07:44 PM
Bodyboarder81
Nov 2, 2015 12:17 AM
