Sound Coming From Rear Side
Old Feb 10, 2014 | 08:41 AM
can84's Avatar
can84
Default Sound Coming From Rear Side
Hi all,
There is a noise coming from the rear side of the car. i put the sound file, if you use headphones in loud volume, you can hear this noise. I m not sure if it is wheel bearings or differential, but i m sure someone here can definetly tell me whats wrong...
this noise starting from 2nd second, and 5th second you can hear very clear.
Car also has exhaust problem, there is a noise coming similar Turbo sound, i will be apriciate if you guys help me about this problem as well.
Regards,
File Type: zip
Old Feb 11, 2014 | 04:21 AM
can84's Avatar
can84
http://vocaroo.com/i/s1kbru15moJJ
you can listen from this link as well, as i said from 2nd second to 6 th second you can hear the noise most clear.
Old Feb 12, 2014 | 10:15 AM
can84's Avatar
can84
c'mon guys, nobody has any opinion ?
Old Feb 12, 2014 | 11:16 AM
jackie chan's Avatar
jackie chan
if its wheel bearings, put the car up very securely on jack stands or a lift and have someone sit in the car and get the wheel speed up. Feel the a-arm(sorry, I don't know if that is what it is, or called, exactly) close to the wheel and see if it is vibrating....that will be a sure sign of a bad wheel bearing.
Old Feb 12, 2014 | 11:21 AM
jackie chan
also a wheel bearing sound will be consistent on different road surfaces
PLAYDIRTY
Oct 12, 2015 07:45 AM
AbyteZero
Sep 22, 2015 09:17 AM
Suffolk350z
Sep 13, 2015 02:43 PM
