2006 350z overheating - Thermostat replacement?
Old Feb 14, 2014 | 06:50 PM
Divine's Avatar
Divine
Default 2006 350z overheating - Thermostat replacement?
Hey guys, so my Z was running perfectly fine yesterday, and today it started randomly over heating. It gets really hot, really fast. Also, my heater does not blow hot air anymore.
My neighbor looked at it, and he says he's 99.9% sure it's not the head gasket (thank god) and he believes it's the thermostat.
Now I'm not really mechanically inclined, but I can figure out stuff at the same time - I've been searching for a DIY on how to replace the thermostat for 350z's but I really cannot find any good ones. Can somebody help me out here? I don't really know how to replace it.
Thanks guys!
EDIT: So I figured out how to get the new thermostat in, car is still overheating. I think there may be an air bubble, so I bled all the air out. I'm letting it sit for a while now. In about a hour, I'm going to try to see if the car works.
All the coolant is flowing correctly, it flows everywhere except it does not go to the bottom radiator hose, that's connected to the thermostat. So that's why I believe it's an air bubble, since I just replaced the thermostat.
If it is not the thermostat or an air bubble, what do you guys think it could be?
Thanks!
Old Feb 15, 2014 | 02:21 AM
myfirstzcar's Avatar
myfirstzcar
No heat=low coolant and/or a big air bubble trapped in the system. Of course it's always a good idea to replace the thermostat if it's got some miles on it.
Old Feb 15, 2014 | 07:23 AM
iStan's Avatar
iStan
ZR
First try adding more coolant and bleeding the air out of it. Search for DIY on that, should be readily available.
If after a few attempts, that does not resolve the issue, then look into the Thermostat. Click search at the top, then advanced search and search title only and you should be good to go.
Old Feb 15, 2014 | 08:13 PM
Landon_G03z's Avatar
Landon_G03z
It's an air bubble. Bleed the system thoroughly. Vq's aren't your common gm indestructible engine where you can just run the water hose straight into the radiator and fill 'er up. Last time I did a coolant flush it took me 2-3 tries to get the air completely out
Old Feb 16, 2014 | 05:51 PM
Divine's Avatar
Divine
Old Feb 16, 2014 | 07:32 PM
Divine's Avatar
Divine
Got it working! Was an air bubble!
Old Feb 16, 2014 | 07:45 PM
SR71's Avatar
SR71
Lead Super Moderator
Old Mar 2, 2014 | 07:56 AM
basicblack@nola's Avatar
basicblack@nola
Cool overheating
For me it was the fan not coming on nissan replaced it and extended the warranty but that was my 06 was young.
Dr.Paulyy
Jul 29, 2019 07:45 AM
reno56
Interior
17
Nov 20, 2015 05:21 PM
nissan1310
Oct 12, 2015 08:54 AM
RyansZ33
Sep 15, 2015 05:54 AM
