tranny grind
Old Mar 8, 2014 | 06:33 AM
timeltel's Avatar
timeltel
Trying Motul 75 w 90. On a cold day, first shift into 2nd means constant pressure on the stick and waiting for the transmission to agree to shift. Through the gears a couple of times & shifts are smooth. Haven't run the Motul long enough to get a good average of MPG but with a South Bend "Black" racing flywheel the gearbox is quiet.
New transmission in Oct. on Nissan's dime @ 46k mile. Last one (OP) sounded like a coffee can full of gravel & hung up between 5th & 6th.
Old Mar 8, 2014 | 08:14 AM
myfirstzcar's Avatar
myfirstzcar
I have no real issues in the cold with redline, except for going into first before coming to a dead stop. It's still no issue for me though, I know how to match 'em up and can double clutch if necessary.
Old Mar 8, 2014 | 09:19 AM
tc0152's Avatar
tc0152
Mine is an 03
Old Mar 8, 2014 | 11:58 AM
Spike100's Avatar
Spike100
^^^ Also have a 2003, but with a transmission replacement (done in 2008 under Nissans generous and fair warranty before I hit 5 years or 60k).
I’m in a cold climate so I use a lighter transmission fluid. I’ve never experienced any issues (noise, grinding, whatever) with the new transmission and my clutch assembly.
--Spike
Old Nov 1, 2017 | 05:15 PM
black93supra's Avatar
black93supra
SOrry to bring back an old thread, but this is where using the search functin has led me. I have an 08 with 160k. i get the random cold morning grind but when the fluid heats up its fine. I also get the same grinding noise after driving for about an hour at hwy speeds of 60-70 mph and then coming to a stop at a light and pressing in the clutch. Usually goes away after about a day. Only thing is i drive for about 30 minutes to work every morning and when i park at work it never does this. Could it be an issue with bleeding the clutch line?? or TOB?
Old Nov 2, 2017 | 09:38 AM
zakmartin's Avatar
zakmartin
Have you ever changed out your tranny fluid? Are you running with the original clutch?
Old Nov 2, 2017 | 03:22 PM
black93supra
To my knowledge its the original clutch. I did schedule a time with the shop on monday to take it in and have the fluids changed and have them bleed the clutch just to be sure. Going to have the trans, diff and clutch fluids all replaced. We will see if that changes anything.
Old Nov 3, 2017 | 12:59 PM
zakmartin's Avatar
zakmartin
Bleeding a 08 clutch is a bear. Definitely good to get the trans fluid changed though. Diff fluid too at that mileage. Let us know how it goes.
Old Nov 6, 2017 | 03:55 PM
tdavis42's Avatar
tdavis42
So what you guys are saying is that if I am hearing a grinding sound with the clutch pedal NOT depressed it's the throwout bearing?
Old Nov 7, 2017 | 09:35 AM
zakmartin's Avatar
zakmartin
The throwout bearing could be the source of the sound. Without a maintenance history on the car and without hearing the sound itself, it's hard to give you an exact diagnosis over the internet.
Old Nov 7, 2017 | 10:29 AM
iideadeyeii's Avatar
iideadeyeii
If it goes away when the pedal is pressed then yes
etkms
Jun 19, 2022 06:30 PM
seagrasser
Oct 11, 2015 03:27 PM
Ace2347
Sep 22, 2015 03:12 AM
rizzla
Drag
Sep 17, 2015 08:44 AM
