ecu reset?
Old Mar 10, 2014 | 11:19 AM
Daytondakid13's Avatar
Daytondakid13
Default ecu reset?
So first off this is a stupid post. Second off i think reseting the edu with my cobb ap would be the same as the petal reset (turn the key on and pump the accelerator like 5 times wait 7 seconds exc) but want to make sure.
I am installing a new camshaft position sensor (driver side bank 2) in my 2007 350z. People suggest you do a ecu reset after you put the sensor in. I have a cobb access port in my car for a tuner, and that can reset the ecu just by pressing a button. Would that work the same way as doing the petal reset or is it any different?
Thanks
Old Mar 10, 2014 | 12:10 PM
verdict.'s Avatar
verdict.
Moved...
Old Mar 10, 2014 | 08:58 PM
RENFRO's Avatar
RENFRO
I don't know the answer to your question...but it's *pedal.
Old Mar 10, 2014 | 11:44 PM
samsniss350z's Avatar
samsniss350z
I would imagine (but stand to be corrected) that if you fitted the cam position sensor and then tried the reset with your Cobb ap and it failed to work then you would have to go ahead and do the 'pedal dance'. People have suggested to you that you do the ECU reset after you've fitted the sensor as it would be totally pointless to do it before.
Old Mar 11, 2014 | 01:03 AM
myfirstzcar's Avatar
myfirstzcar
Or just disconnect the battery overnight.
Old Mar 11, 2014 | 08:18 AM
verdict.'s Avatar
verdict.
https://my350z.com/forum/engine-and-...ecu-reset.html
Whiskers1996
Tuning
Aug 1, 2020 04:09 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
