wheel bearing or tire noise yes i searched
Old Mar 20, 2014 | 04:34 PM
Toneloc's Avatar
Toneloc
Default wheel bearing or tire noise yes i searched
I jacked up the car and check all four wheels no play or wiggle in all four of the tires 12 to 6 or left too right. Sound doesn't change braking or turning....sounds like I have mudder tire in the passenger rear increases in sound by mph...
No wiggle all good right?
thoughts?
Old Mar 20, 2014 | 06:19 PM
Toneloc's Avatar
Toneloc
Anyone please?
Old Mar 20, 2014 | 06:46 PM
jhc's Avatar
jhc
General & Tech Moderator
MB swap out spare in that spot for tire noise. Did you turn the tires when they were up to ck for binding or noise? Unusual tire wear...
Old Mar 21, 2014 | 02:07 AM
Toneloc's Avatar
Toneloc
Out made a different noise on the passenger rear...o wouldn't call it clicking our grinding...I'm thinking I was hearing the diff gears
Old Mar 21, 2014 | 02:46 AM
padilla03z's Avatar
padilla03z
Video? U got an alignment?
Old Mar 21, 2014 | 05:32 AM
AshMan's Avatar
AshMan
Club Moderator
the Hot Spot
I had one wheel hub bearing go slightly bad. It would make noise when I was @ freeway speeds. So, when I was on the freeway, I would veer in the lane slightly from left , then to right. The noise would go away when I turned in one direction & got louder when I turned the other.
If it's tire wear, you're going to hear noise all the time.
Old Mar 21, 2014 | 06:03 AM
myfirstzcar's Avatar
myfirstzcar
Tire might be cupped from too much toe and/or camber.
Old Mar 21, 2014 | 12:56 PM
Toneloc's Avatar
Toneloc
ill check tires, I had a friend that has had multiple wheel bearing go bad over the year go for a ride with me....we did confirm if I turn to the right hard the noise does get louder...he is thinking it isn't bearings...either tires or half shaft....so he said research and monitor it...my last alignment was 10000miles ago...yes every other weekend I do spirited drives down the twisties... its not grinding or clicking it confused him also...bone stock suspension
Old Mar 21, 2014 | 04:45 PM
myfirstzcar
Parking brake working good?
Old Mar 21, 2014 | 06:18 PM
Toneloc's Avatar
Toneloc
it works I would say I pull it up 80% of the way for tight
Old Mar 22, 2014 | 11:34 PM
jds4181t's Avatar
jds4181t
another way to check for a wheel bearing is to jack up the vehicle and hold the spring while spinning the wheel, sometimes you can feel it but cant hear it
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
samansharif
Sep 25, 2015 12:31 PM
