Rough idle due to mods? Tune..?
Old Mar 22, 2014 | 10:38 PM
Maffucci10's Avatar
Maffucci10
Default Rough idle due to mods? Tune..?
Ok so I have an 03 350z track. Right now im currently running a stillen intake, kinetix plenum, mrev2, stillen engine damper, and a muffler delete. The idle is a little rough with a little more vibration but nothing crazy (from what I know the extra vibration is from the stillen engine damper) If im in 1st and go to about 5 or 10 mph and put the clutch in, the revs drop down to about 300-500 and almost acts like its going to stall. Could these make my car run lean or rich? And would doing an uprev tune fix the idle and somewhat almost stalling problem?
P.S.
Still planning on getting art pipes and tdx2 so if the tune would fix it how bad would it be keeping my car the way it is until everything is put on because I don't want to tune it now and than re-tune it later.
Old Mar 23, 2014 | 02:10 AM
JCITY's Avatar
JCITY
Think about it.With the mods you have done that have opened up you engine a bit,
its saying ,"I'm hungry".
Its running lean.
A tune would fix this.
For the cost,I'd wait till I get all my mods done before the tune.
Old Mar 23, 2014 | 06:45 AM
radiocrash's Avatar
radiocrash
Get it done sooner than later and take it easy until you get the tune.
Old Mar 23, 2014 | 07:05 AM
Calinismo350z's Avatar
Calinismo350z
for fact car needs need a tune to make sure car is running good. However with the mods you have right now shouldn't be doing that. I had almost same mods just with a borla exhaust and my car never had idling issues. You should start looking for a vacum leak. It might not be a big leak since you don't have your service light one. good luck.
Old Mar 23, 2014 | 08:56 AM
350slug's Avatar
350slug
My G had a similar issue with the idle dropping when I let off. It ended up being a dirty throttle body. Get a gasket, unplug your battery, take it off clean it carefully, reinstall, do the resets and it should be fine. Good luck
Old Mar 23, 2014 | 08:58 AM
350slug's Avatar
350slug
Check for a leak first by spraying tb cleaner and listening for a change in idle. But I've had more than one vq act up over a dirty tb
Old Mar 23, 2014 | 09:39 AM
Maffucci10's Avatar
Maffucci10
Looks like im cleaning the throttle body tmrw, hopefully that'll fix it.. thanks guys
350z82
Oct 1, 2015 06:25 PM
