Grinding issues at times wont accelerate
Old Apr 20, 2014 | 02:00 PM
Venom36's Avatar
Venom36
Exclamation Grinding issues at times wont accelerate
I know there has been posts about this issue in the past but I needed some help from my fellow 350z owners.
Here whats going on my engine was replaced in January before I replaced I had 107,000 miles. I replaced to an engine that had only 60,000 miles the engine is now great but after it was replace a couple days later my 350z started to grind. I took it to a transmission shop and it was the throw out bearing I also replaced the flywheel. The grinding stopped then a week later 5th gear started to grind. So i took it back to the transmission shop and they replaced the 5th gear syncro and update a shaft. Everything was good for a week and then 3rd, 4th and reverse started grinding. Not only have the gears started grinding but today I was at a stop and I couldnt go into any gear even though my clutched was pressed all the way . The car just started to vibrate couple second later it allowed me to go into 3rd gear to get home. As you guys can imagine im frustrated since i have spent a ton money and i cant even drive my car now.
Is it my transmission? clutch is also less than 6 month old. I have had my car for 3 years and for 2 years it gave me no problems until now.
P.S is z1motorsports an official and reliable 350z source?
Help would be great appreciated
Old Apr 21, 2014 | 04:29 PM
Spike100's Avatar
Spike100
What year is your Z? It sounds as though repeated attempts at a repair have only resulted in more problems. I can understand your frustration. You spent time and money and have gotten nowhere.
Transmission repairs typically are accomplished by swapping out for a rebuilt unit. Since repeated attempt at repairing your transmission have been unsuccessful, ask the shop to swap out your transmission and credit the amount you have paid so far. --Spike
Pleask
Dec 21, 2021 03:17 PM
sherm
Apr 11, 2020 05:21 PM
Fixxxercask
Nov 9, 2015 11:10 AM
Depravity
Oct 1, 2015 04:49 PM
