Sputtering/Power Loss PLS HELP!!!
Old May 17, 2014 | 07:20 PM
zBOSSER's Avatar
zBOSSER
Default Sputtering/Power Loss PLS HELP!!!
I recently bought my 350z about 2 months ago car ran great till today. I was driving on the highway and as i accelerated the car sputtered making the rpms go up in a bouncing fashion. The car felt held back, it happens everytime i accelerate. it happens in every gear 1st - 6th gear. When the car is in idle it makes a popping noise its very hollow and it effects the exhaust note drastically. Sounds as if the car is misfiring. Is this a spark plug/ coil replacement or is this something more serious. PLS help.
Old May 18, 2014 | 05:20 AM
padilla03z's Avatar
padilla03z
Read the code ur engine is putting out. Kinda sounds like a misfire from ur explanation but who knows. If ur engine code is 030x then its a misfire if the last number is anything but a 0 then that's the cylinder that's misfiring. When mine mid fired it was just a coil pack but idk what urs is
Old May 18, 2014 | 06:13 AM
Dajersyrat's Avatar
Dajersyrat
Sounds like a bad coil pack to me but try the spark plugs first. Some Z's Misfire at idle due to a lean idle condition, common issue from day 1.
apex locator
Jul 23, 2021 02:27 AM
ablaine
Nov 29, 2016 10:13 AM
