Scraped Flex Joint In Need of Info
Old May 19, 2014 | 08:19 PM
greyfoxx's Avatar
greyfoxx
Default Scraped Flex Joint In Need of Info
My flex joint seems to scrape as I reverse out of my driveway, it doesn't happen every time and when I go down it my driveway it doesn't scrape at all. I'm aware that the weave is just protection to the pipe itself am I right? Here are some pictures of it, is there anything I can possibly do to prevent it from getting any worse? I sometimes maneuver out without scraping but I haven't found the exact way to do so just yet.
Old May 20, 2014 | 12:44 PM
RedBullRR's Avatar
RedBullRR
I just replaced my entire exhaust due to a huge air leak from the same problem. Once that flex weave goes to **** it will leak...
Old May 20, 2014 | 01:44 PM
dcains's Avatar
dcains
The flex weave doesn't make the seal, the corrugated pipe inside does. If you don't scrape the joint further, you're fine. Practice getting your driveway technique right - maybe drive at an angle, or if there's a particular high spot, maybe you can shave it.
Old May 20, 2014 | 04:46 PM
greyfoxx's Avatar
greyfoxx
thanks! I was extremely cautious in how i backed out today and didn't scrape at all. All it takes is patience and if patience will save my car, it would definitely not hurt me to spend a little bit longer back out of my driveway lol. But I remember being told the weave was only a cover before also, no leak yet or different sounds so as long as I dont further harm the flex section hopefully I will be fine.
350Z_Al
Oct 29, 2020 07:44 PM
nanotech
Oct 2, 2015 05:02 AM
Tochigi_236
Sep 27, 2015 03:40 PM
