P0327 Sub Harness -Quick Fix-
Old Jun 24, 2014 | 05:53 AM
04DaytonaZee's Avatar
04DaytonaZee
Default P0327 Sub Harness -Quick Fix-
Hey guys, I'm a tech at a Honda dealer and the other day I noticed my 2004 350z had a P0327 stored code, which quickly came back after being deleted. Knowing the OEM sensor was at least $100 but the sub harness was only $30 I wanted to try just replacing the sub harness, but the process of removing the manifolds and fuel system was tedious. So...
Our Master Tech and I took two long flat-head screwdrivers, bundled them up together with a homemade coat hanger hinge, and used the hinge as a point of flex to create a very long set of pliers out of two screwdrivers. Sorry that I do not have pictures...
Then with a light we went through the slot in the timing cover and, with a coat hanger, pulled on the wire towards the front of the vehicle while unplugging the connector at the Knock Sensor with the screwdriver pliers. Took a total of 30 seconds to get it unplugged. Next, I stuck a knife down behind the plenum and cut the tape connecting the knock harness and another harness together. Last, I lifted the vehicle up in the air and had easy access to the other harness plug underneath the coolant pipe behind the motor.
Knock sensor sub harness removed. After inspecting the harness I found corrosion near the factory taped up area inline of the sensor wire.
To install the new wire we attached the rear plug to a coat hanger stick and ran it through the timing cover hole and out the back underneath the plenum. Pull it through and then work the plug with the screwdriver pliers onto the knock sensor and seat the clip. Then lifted vehicle back up, reinstall rear plug and then I zip-tied the sub harness wire to another wire to prevent as much movement as possible.
P0327 Fixed. Wasn't the oem knock sensor, was just the harness. This process took a total of 15 minutes (we had the tools set up beforehand).
Hope this helps someone.
Old Jun 24, 2014 | 06:27 AM
steven350's Avatar
steven350
Nice job lol.... I took everything off... I don't like working in tight spaces like that lol
Old Jun 24, 2014 | 05:09 PM
myfirstzcar's Avatar
myfirstzcar
".....And then we wrapped the entire engine in duct tape, just to be safe".
Just kidding, that's very smart, nice job!
Old Jun 25, 2014 | 05:29 AM
Roadrunner3000's Avatar
Roadrunner3000
I did it the same way one month ago :-)
Old Oct 9, 2014 | 11:31 PM
yellowspecv's Avatar
yellowspecv
Do you really need a lift to get the back harness undone ?
Old Oct 29, 2014 | 07:41 AM
taywan's Avatar
taywan
I'm about to attempt this so I dont have to take apart all this **** for a tiny little harness. I already habe the other end off and zip tied from months ago. Z is running a little wierd at top of 3rd, 4th, etc. I've had the z1 harness for a very long time...want to put it on to see if this resolves the issue. Thanks for the post
Old Oct 29, 2014 | 08:45 AM
taywan's Avatar
taywan
Wow. Super fast. Above was all I needed^^^
m_0g
Jun 3, 2021 10:05 AM
HoBrahYouStink
Jun 24, 2016 10:58 PM
speedsniper
Sep 14, 2015 08:46 AM
BlinkerFluid
Sep 8, 2015 10:06 AM
