Problem - Slower than it should be.
Old Aug 27, 2014 | 07:04 AM
breilly127's Avatar
breilly127
Default Problem - Slower than it should be.
Hi all. First post. I apologize if it is in the wrong section as I am new to the site.
I just bought a 2003 Enthusiast 350z with 70,000 miles. The numbers float around a bit, but online it says it should get to 60 somewhere around 5.5 or so. I'm consistently getting 6.2's. The only modification was a aftermarket grill that the previous owner put in and a K&N drop in filter I put in.
Does anyone have any idea what the problem might be?
Or a solution?
Is 5.5 a correct estimate for what it should be?
I'm looking to start adding mods, but I want to make sure I'm starting from a good baseline. WHY IS IT SO SLOW!?
Old Aug 27, 2014 | 07:10 AM
350zHalleck's Avatar
350zHalleck
I'm willing to bet it's the driver.
Old Aug 27, 2014 | 07:43 AM
travlee's Avatar
travlee
Master
i second this
Old Aug 27, 2014 | 08:00 AM
breilly127's Avatar
breilly127
While I appreciate your constructive criticism, I disagree. I know that you know nothing about me, but I know how to get a car off a line. There is something wrong with the power. It just doesn't seem to be there. Is it something that a tune-up could possibly fix? and what would it be fixing? I'm not a beginner at driving quickly, but I'm just starting out at tuning. Actually, I haven't started yet except for dropping in a K&N filter into the air box which is more of a joke than anything. I just want to make sure I'm getting the most out of my new car, that's all. And while it sounds great (still stock), it's not moving the way I know it should. Any help?
Old Aug 27, 2014 | 08:11 AM
cashmoney03's Avatar
cashmoney03
There's way to many variables on a 0-60 run. Worthless imo. Run it at the drag strip or throw it on the dyno. A general tune up can't hurt anything. Let's also not forget that every car is built different.
Old Aug 27, 2014 | 08:21 AM
breilly127's Avatar
breilly127
Ok. Do you know how a tuneup might improve performance?
Old Aug 27, 2014 | 08:27 AM
travlee's Avatar
travlee
Master
it wont really.......
Old Aug 27, 2014 | 08:29 AM
cashmoney03
What he said^^^ I said it can't hurt anything. Didn't say it would really help unless you've got some very weak plugs and coils or really nasty injectors.
Old Aug 27, 2014 | 08:38 AM
breilly127's Avatar
breilly127
Okay. Thanks for your help.
Old Aug 27, 2014 | 09:19 AM
tommy smith's Avatar
tommy smith
Default it's a 2003
Old Aug 27, 2014 | 09:27 AM
Syner's Avatar
Syner
Originally Posted by tommy smith
Many cars that old are in the junkyard.
Gearing up for another 370 rant? **** off.
Old Aug 27, 2014 | 09:39 AM
350zHalleck
He doesn't get it and never will
Old Aug 27, 2014 | 09:45 AM
tommy smith
Default you're saying
Old Aug 27, 2014 | 09:52 AM
Syner's Avatar
Syner
So an 11 year old car that might have been started thousands of times would have the rings, cylinder walls, bearing clearances, cam lobes & much much more stuff in the same condition & performed as an almost new car that was tested by car magazine's expert drivers in 2003 ????
OK.
A properly maintained car won't last 11 years? You said junkyard, not "subpar performance due to age."
OK.
Old Aug 27, 2014 | 09:58 AM
tommy smith
Default ....................
OK.
Old Aug 27, 2014 | 10:01 AM
Syner's Avatar
Syner
So what was the point of your response? Just a basic inference?
"the sky is blue"
Old Aug 27, 2014 | 10:05 AM
tommy smith
Default I thought
"the sky is blue"
Old Aug 27, 2014 | 10:34 AM
Jennifer 2's Avatar
Jennifer 2
If your car normally runs well (as it should with only 70k miles) but seems slightly off the mark with full throttle high RPM sprints consider checking for proper operation of the knock sensor. It could be that Knock sensor is pulling the spark timing back from full advance at high RPM.
A man in my neighborhood has a Subaru WRX sti that was more than a match power wise to my Z. On a long steep hill near us I was able to not only pull around and pass him, but I kinda blew his doors off as I went by. It turned out an overly reactive knock sensor was the problem.
I don’t know how you can check for this. Or even if this is as common an occurrence with the Z as it can be with Subaru’s, but both cars use a very similar system.
Old Aug 27, 2014 | 12:45 PM
iideadeyeii's Avatar
iideadeyeii
Run a 1/4 miles a few times
Old Aug 27, 2014 | 12:48 PM
gabez33's Avatar
gabez33
OP, go put your stock air filter back in and give it another shot
