Driver's door lock won't unlock
Old Sep 19, 2014 | 06:57 PM
Cujucuyo's Avatar
Cujucuyo
Unhappy Driver's door lock won't unlock
Hey guys, this issue has been happening sporadically and for some reason I always forget to mention it when at the repair shop.
Basically my driver's door lock gets stuck midway when trying to unlock, it locks properly though. You can hear a distinct "twang" when trying to unlock, here's a video, sorry about the low light:
https://www.youtube.com/watch?v=nZyX...ature=youtu.be
When this happened it had an odd workaround, I'd put the key into the door, turn to the left until the window rolls down entirely, then sometimes it would unlock.
Another fix would be to lock and unlock the car using the FOV but it didn't work.
Even from the inside it won't unlock as you can see in the video.
Any help would be appreciated. Thanks in advance.
Old Sep 19, 2014 | 07:31 PM
Syner's Avatar
Syner
Have you taken the door panel off to look inside?
Old Sep 19, 2014 | 07:34 PM
Cujucuyo's Avatar
Cujucuyo
Nope, can't open the door.
Old Sep 21, 2014 | 06:09 PM
Cujucuyo's Avatar
Cujucuyo
Update: Got the lock unlocked. God damn it was tedious, I had to insert the key and lightly moved the key from left to right but with enough force to "try" and unlock it finally budged after about 30 times.
Seems like lack of lubricant, it works properly now but I'll have it checked tomorrow and update for future reference.
Old Sep 21, 2014 | 08:49 PM
jhc's Avatar
jhc
General & Tech Moderator
No lube required- these are simple plastic connectors and sliders. Have you pulled the inside door panel? If not, see how they work, and learn.
GL
lapham3
Oct 7, 2022 03:15 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Mattg350z
Oct 2, 2015 06:51 AM
Ganglio
Europe
Sep 26, 2015 07:06 PM
