OBD2 Error Code - 02 Sensor P2A03
Old Oct 1, 2014 | 11:37 AM
dczx's Avatar
dczx
Default OBD2 Error Code - 02 Sensor P2A03
No recent changes or modifications. I think the 02 sensor is going out but I am not sure how to check which one.
I saw a few other people with P2A03 but they were generally after mods.
Is there a way to tell if it's a certain sensor or which one? (The left and right bank seem to have considerably different trims as well).
meta-info header:Error Codes
file version:1
type:5
time:1412187425344
codes:P2A03,
codes_p:P2A03,
codes_raw:43012A03;;;;
codes_p_raw:47012A03;;;;
Error Codes
P2A03
O2 Sensor Circuit Range/Performance
Vehicle speed (Speed) 2 MPH
Intake air temperature (IAT) 84 °F
Long term fuel % trim Bank 2 (LTFT2) 4.68 %
Long term fuel % trim Bank 1 (LTFT1) 0.78 %
Engine coolant temperature (ECT) 170 °F
Fuel system status (FSS) Closedloop:usingO2sensorforfuelmix
MAF air flow rate (MAF) 9.93 g/s
Calculated engine load value (EngineLoad) 29.8 %
Timing advance (TA) 35.0 °
Engine RPM (RPM) 975 rpm
Short term fuel % trim Bank 2 (STFT2) 4.68 %
Short term fuel % trim Bank 1 (STFT1) 1.56 %
Pending Codes
P2A03
Raw values
Error Codes 43012A03;;;;
Panding Codes 47012A03;;;;
meta-info footer
Old Oct 1, 2014 | 05:38 PM
johndoesdamage's Avatar
johndoesdamage
Swap them from left to right clear your code and see if it pops back up
liqalu04
Jan 2, 2022 12:58 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
