Tires were replaced and now my car somewhat sways away?
Old Oct 15, 2014 | 10:40 PM
fairlady9693's Avatar
fairlady9693
Default Tires were replaced and now my car somewhat sways away?
So after my rear wheel tires were slashed, they were brought into the shop to be replaced. Now that I finally had her back, the car feels like it looks control or sways when going 100 kph. It just doesn't feel like I'm in 100% in control.
I've been reading online that it could be that it needs alignment, or it could be tire pressure? Does it matter that the rear tires are different than the front ones?
Old Oct 16, 2014 | 04:46 AM
mr. sparco's Avatar
mr. sparco
Did you replace them with cheap or less grippy tires? That or the wrong sizing or type of tire, for example using tires intended for a small suv or minivan instead of performance.
Old Oct 16, 2014 | 11:05 AM
fairlady9693
Insurance replaced them. They're pretty grippy.
Old Oct 16, 2014 | 11:52 AM
Bmurray350z's Avatar
Bmurray350z
Here are some things to check:
-Tire pressure
-Alignment (probably your problem)
-Wheel bearings
-LCA bushing went out
Old Oct 16, 2014 | 02:22 PM
samsniss350z's Avatar
samsniss350z
-Tire pressure
-Wheel bearings
The front should have the same tires on the front, same size and same spec. This also applies to the rear. never mix tires on the same axle. If you're encountering problems then i agree with BMurray, get all of the above checked out, one of which undoubtedly will be your problem.
etkms
Jun 19, 2022 06:30 PM
JjL
East Canada
Jun 12, 2019 03:04 AM
Nihsnek
Feb 9, 2016 12:57 AM
Vigman
Nov 17, 2015 04:34 AM
350Z Project X
Oct 17, 2015 05:16 PM
