Needing some help!
Old Jan 1, 2015 | 09:38 PM
Tessa350z's Avatar
Tessa350z
Default Needing some help!
Hello I am currently in the search for a part for my '03 Z. I was replacing the radio and I accidentally nicked the ribbon that is connected to te climate control *****. Where can I get a replacement? And how much?
Old Jan 2, 2015 | 02:48 AM
bad boyz's Avatar
bad boyz
The part is called a temperature control module I looked it up on Ebay they have one for sale for 100.00 should be an easy find also if you want a brand new one you can check with a Nissan dealership probably more expensive or even just google the part description and see what you come up with anyway best of luck!!
Old Jan 2, 2015 | 08:11 PM
ishyne22's Avatar
ishyne22
scrape back the plastic exposing the wires. solder on some new wires and cover with liquid electrical tape. Or if the tear is close to the connector piece. remove the connector cut off the excess and scrape back exposing the wires and reattach the connector. that's what I did. good luck.
Old Jan 3, 2015 | 09:14 PM
samsniss350z's Avatar
samsniss350z
I'd try a breakers yard as chances are you'd find one there.
sherm
Apr 11, 2020 05:21 PM
