Headlight Condensation!!!!
Old Feb 18, 2015 | 05:22 PM
joonvang's Avatar
joonvang
Default Headlight Condensation!!!!
Hello,
I recently did a mod on my 08 headlight and for the first month, everything was fine, no condensation what so ever. Boom second month in and the driver side start to fog up only when the headlights are turn on than it freezes. Its winter where I leave but at times when the roads are clear, i like to take my z out. I re sealed the highlight with its own black glue thingy that was still on it. I also seal the outside with clear silicone. After the second month since it fog up, I took out the driver side and resealed it with black silicone on the outside edges. Now the passenger side is fogging up a little bit now too. I'm not sure at this point what do do since the condensation keeps on coming back regardless of the double silicone seal. Any help/opinion is much appreciated. I'm trying to avoid buying new headlights.
Thanks
Old Feb 18, 2015 | 05:35 PM
travlee's Avatar
travlee
Master
you are not completely sealed somewhere... where, who knows.
you should have used rubber butyl to seal it
Old Feb 18, 2015 | 05:47 PM
joonvang's Avatar
joonvang
I mean, the 08 headlight do have these small tubes coming out of the headlight with somthing like sponges inside them. so the headlight to begin with wasn't seal up completely....ah man sucks...
Old Feb 18, 2015 | 05:54 PM
travlee's Avatar
travlee
Master
that is the exact reason i never opened mine up. bmcann on here is parting out his car, has blacked out headlights if you can't find or correct it.
good luck sir
Old Feb 18, 2015 | 06:42 PM
DieselandZ's Avatar
DieselandZ
Dry it out before resealing if any moisture is in redesign it just keeps trapping it in there. And when it heats up it just rebuilds condensation on the lense. On my diesel I had the same problem and I removed the lense and used a heat gun on low to dry it. Then resealed it looks brand new.
Old Feb 18, 2015 | 07:36 PM
joonvang's Avatar
joonvang
Thanks for the tip. I probably will do that, clean the inside with lint free cloth first, than heat it up with blow dryer than seal it again...
Old Feb 18, 2015 | 08:31 PM
DieselandZ's Avatar
DieselandZ
Yeah it's a pain but I was like you and tried a lot of things. Just take your time and try to do it in as little humidity as possible.
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
bcoffee20
Nov 19, 2015 06:39 PM
JGee450
Sep 30, 2015 04:32 AM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
