Compression Test
Old Mar 13, 2015 | 03:15 AM
Whiskers1996's Avatar
Whiskers1996
Question Compression Test
I cranked it 4 times and got 190/190/190/190/192/192 . When I cranked it till it stopped I got 220-222. I see that the compression is suppose to be 145-185, so did I do something wrong? Carbon build up? Defective gauge?
New tester from autozone
Warm engine
Dry test
Valve covers replaced not too long ago
I did see another thread with he same question years ago but no answer.
Old Mar 13, 2015 | 07:31 AM
iideadeyeii's Avatar
iideadeyeii
I'm always confused by this also. When I used to test T8D engines I used to get 210 compression (cranked a few times)
Old Mar 13, 2015 | 02:19 PM
Sleepiedaze's Avatar
Sleepiedaze
turn the key until the needle stops moving. On "MOST" motors you should see a reading between 175 to 195. since your motor on all cylinders is reading close to the same then its safe to say your meter is good. try it again on a cold motor with a different tester. it will probably read the same.
did the same on my nissan 240 and my 350z. compression on the 240 was
190
190
20
190
which means cylinder 3 was toast.
on my z it read all equal numbers except for one was about 2 points off. you did it the right way. guage is probably off or just reads different. my 2 guages read 2 different numbers on the same car. just 10 or so off.
Old Mar 13, 2015 | 06:53 PM
Whiskers1996
So is there any way to find out where my compression ranges from high to low compared to other de's? I'm happy I got such close numbers though.
Old Mar 16, 2015 | 07:03 AM
iideadeyeii
Last time I got a tester from autozone the fitting unscrewed and got stuck in the head of the car I was working on. What a pita to get that out
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
