Neutral Idle Revving on its Own
Old May 3, 2015 | 08:05 PM
Adrian Leung's Avatar
Adrian Leung
Default Neutral Idle Revving on its Own
Hi, I have a 2005 350z with 40,000 miles. Today I changed the oil and oil filter, and changed my front brake pads and everything went smoothly. My friend decided to check my air filter, and used an air gun to try and clean around. When I started up the car, everything was fine and I started driving a block down the road. When it was in neutral it suddenly began revving on its own, and I am not sure what is going on. Does anyone have any idea what the issue may be? I put in 5 Quarts of Royal Purple SAE 10w-30, is that wrong?
Here is a video of what is happening. https://www.youtube.com/watch?v=5P-t...ature=youtu.be
I appreciate any help with this, I'm a dummy
Old May 3, 2015 | 08:12 PM
FOOKhonda's Avatar
FOOKhonda
you have a vacuum leak somewhere, if you have the stock air box, maybe he didn't close it? Or you detached some line somewhere and didn't reattach it. You could smoke test it to see where the leak is.
Old May 3, 2015 | 08:21 PM
Adrian Leung
That might be it, thank you. I will look over everything tomorrow and double check.
Old May 4, 2015 | 06:23 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Depending on how aggressive your friend was with cleaning the airbox with compressed air, he may have damaged the MAF sensor. Your VQ is surging because this sensor is proving conflicting information to the ECM. Do NOT blow compressed air around such sensitive components.
liqalu04
Jan 2, 2022 12:58 PM
05UltraYellow
Sep 24, 2015 05:41 AM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
Darkspy
Sep 7, 2015 09:09 PM
