Rust under fuel filler door
Old May 8, 2015 | 07:59 AM
Tony1M's Avatar
Tony1M
Default Rust under fuel filler door
A very inexpensive Z has only the following rusted area.
What I'd like to determine is whether this rust can be effectively and permanently repaired.
Has anyone here had a similar rusted area and, if so, how did you deal with it and how has that fix worked out over the long term?
To the rest, how would you deal with it if it were your vehicle (other than selling the vehicle)?
Thanks.
Old May 8, 2015 | 08:20 AM
Syner's Avatar
Syner
Screams winter driven to me. I'd guess there is underbody rust as well.
I'd assume the easiest (and likely least expensive) way to fix it would be a new quarter panel. But even then, it won't be cheap.
Old May 8, 2015 | 11:19 AM
dkmura's Avatar
dkmura
General & DIY Moderator
I haven't seen that kind of rust on a Z before, but I'd consider trying a rust converter on that area. You'd still need to properly prep the area by taking off the filler cover and masking the area around the filler neck. Then use a steel brush or other device to scrape back the area that's rusty. Once all the rust is exposed, apply the rust converter and allow it to dry in that area. After it dries and gets hard, it can be primed and painted.
Old May 12, 2015 | 01:40 PM
rancor's Avatar
rancor
Remove rust don't try and convert it that's usually only a short term fix. Grind off the rust and use a rust remover like navel jelly to get the rest. Then you can body fill if necessary and paint.
Old May 13, 2015 | 08:31 AM
Syner's Avatar
Syner
It looks like it's bubbling under the seams. That would be a lot of grinding.
Old May 14, 2015 | 06:52 AM
rancor's Avatar
rancor
Yes it would and but I would think it would be worth it to try over dealing with spot welds. Replacing the panel would be the best, maybe correct, way but I don't think it would be the least expensive.
Old May 14, 2015 | 07:13 AM
Syner's Avatar
Syner
lol my way would be the most expensive.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
