03" 350Z 2WAY LSD help!!! please
hi guys, i got a 03 350z manual 6 spd.
i just installed br bc coilovers and sway bars and aftermarket lower control arms, and drive no problem,
took it to the shop, to get a 2way kazz lsd installed, and get the car aligned the other day, when they pulled it off the rack the tcs,abs,brake, and slip light came on, now i cant find the problem, any help??
i tried the reset ecu procedure, my z doesnt have the "service engine soon light", but the check engine icon light does come on, and stays on and doesnt blink.
dash lights
http://tinypic.com/r/2ro73mp/8
reset proceedure.
i have not tried leaving the car unplugged for 24 hours. what do i do? i just wanna clear the codes.
dash lights
reset proceedure.
Check to make sure the wheel speed sensors were put back on and plugged in (and they don't look damaged).
Check to make sure the tone ring on each stub axle is aligned properly with the sensor. If they are misaligned (ie. the axle looks like it is popped out slightly from the diff), the shop might not have used the correct combination of axles, not used the circlips, or there was a mixup on the diff part #.
Unplug the battery overnight if you aren't sure you got the ECU reset procedure correct.
Justin100
Nov 29, 2015 03:58 PM
bcoffee20
Nov 19, 2015 06:39 PM
