Just got alignment, steering wheel slightly off, pulls to the right
Old Jun 18, 2015 | 09:47 AM
DesertSleeper's Avatar
DesertSleeper
Default Just got alignment, steering wheel slightly off, pulls to the right
Hello fellas, I replaced my shocks last weekend so got an alignment yesterday. When I drove off I noticed the steering wheel is not completely centered, I have to steer slightly left to go straight, and if I let the steering wheel go at freeway speeds it pulls to the right hard.
I took it back to the alignment shop (who I've been using for a couple of years now with no previous issues), he put it back on the rack and, per the computer, the steering wheel is dead centered. He assures me the alignment is perfect and I must have a defective tire.
I replaced tires less than two months ago, and even after replacing the shocks last weekend I could have sworn the steering wheel was straight and it wouldn't pull. He claims the steering wheel was way off before the alignment and I probably just didn't notice it.
Has anyone ever experienced anything similar before?
Thank you in advance for any input
Old Jun 18, 2015 | 09:55 AM
JCat's Avatar
JCat
If your mechanic or alignment shop can't fix it, they are not very good at what they do.
Visit a TOP-TIER tire shop. Not one of the cheap chains. Find one that is an expert at problem solving these type of problems.
(My "guy" for example, is on a NASCAR team and is responsible for tuning the suspensions)
I discovered that most of the cheap chain stores THINK they have good equipment and technicians . . . . . but it is simply not true.
Old Jun 18, 2015 | 10:13 AM
DesertSleeper
Yeah I was thinking the same thing. I just really hadn't had any issues with this shop before so I didn't have the need to find a better spot, but it's definitely time.....
That's pretty cool that you have a nascar car quality alignment guy though.....if u don't mind me asking, how much does he charge u for an alignment?
I just made an acquaintance that has a shop and does alignments the old fashion way, with strings and all. Guess it's much more accurate than the machine but takes a lot longer depending on the set up u want.....
Old Jun 18, 2015 | 12:46 PM
RedBullRR's Avatar
RedBullRR
Have the same problem and it's driving me nuts. Gonna bring it to another shop. More then anything the steering wheel not being dead center just irks the hell out of me
Old Jun 18, 2015 | 01:01 PM
JCat's Avatar
JCat
I have coil-overs with adjustable height, and the SPC adjustable camber kits at all 4 corners.
Unlike the stock setup, EVERYTHING can be adjusted.
Best money I've spent on the -Z-. The handling performance is vastly improved.
Old Jun 18, 2015 | 06:58 PM
rustyschopshop's Avatar
rustyschopshop
More than likely your caster is off you may want to check your radius arm bushings.
Old Jun 18, 2015 | 10:25 PM
DesertSleeper
Thanks for the input fellas
I know exactly what u mean. I'm gonna do the same, found a spot about hour away that specializes in alignments so i'm gonna make the drive, it's bugging the s$%# outta me
Yeah Im lowered on hotchkis right now, it works for me, I really don't need height adjustability. I have the SPC for the rear only, Ive been wanting to get the adjustable arms for the front.
The guy at the alignment shop told me rotate the front tires left to right (since they're not directional) and if it pulled to the left instead that would confirm it's a bad tire. Swapped them this afternoon and its doing the exact same thing, so its gotta be the alignment.
Old Jun 22, 2015 | 08:17 AM
terrasmak's Avatar
Post the alignment sheet
Old Jun 23, 2015 | 11:17 AM
DesertSleeper
Default Alignment sheet
I swapped the front tires as the tech suggested and it was still pulling to the right. Ended up taking it to a different spot in Glendora that does alignments the old school way. They spent about an hour on it. They said the toe was off in the front but the rear required a bunch of work. They straightened out my steering wheel too. It seems to drive smoother now, but the pull to the right is still there.....
Old Jun 30, 2015 | 07:20 AM
JCat's Avatar
JCat
If the pull is still there, I would find a shop or technician that would be willing to play with the settings until it is gone.
