driver side window malfunction....
Old Aug 19, 2015 | 12:03 PM
difranchise's Avatar
difranchise
Default driver side window malfunction....
Hey guys, thanks ahead of time.
My driver side window does:
1. Does Not go all the way up with one push
2. Does not go down unless I hold the button and shut the door
3. Does not "synch" shut when the door is closed to reduce wind noise
Also, when the window is going up it sounds like it is struggling to do so.
Is my motor going?
Easy fix or go to the dealer???
Old Aug 19, 2015 | 12:55 PM
jhc's Avatar
jhc
General & Tech Moderator
You don't say year or miles so
1) search "window reset/relearn"
2) if that fails take the motor apart and clean inside w CRC electronics cleaner.
3) if that fails replace motor and perform reset.
It's not hard, my cleanup has lasted 2 yrs. Do some homework, gl
Old Aug 19, 2015 | 01:42 PM
difranchise
2006 w/ 58k.
What do you mean by clean up?
Old Aug 19, 2015 | 01:53 PM
jhc's Avatar
jhc
As the brushes wear down they leave a carbon dust all over the inside. Kinda causes shorting/voltage drop on the armature. You gotta get that dust out. It's not hard, I would nvr pay for this repair. Take the door pull off then inside panel and you're there.
Old Aug 20, 2015 | 07:01 AM
difranchise
I did a little research and found some decent articles on motor replacement. I will buy a motor ahead of time so that if it is needed I will have it. Once I have done the repair I will post up. thanks
Old Aug 20, 2015 | 08:56 AM
jhc's Avatar
jhc
Smart man. Prolly just put new 1 in since some places don't accept electric returns?
Old Aug 20, 2015 | 01:08 PM
difranchise
Yeah, I will more than likely just replace it once I strip down the door. I would rather do that than have to go back in there because a cleaning didn't do the trick
lapham3
Oct 7, 2022 03:15 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
samansharif
Sep 25, 2015 12:31 PM
