5th gear not located where it used to be
Old Nov 8, 2015 | 07:40 AM
Bak3rme's Avatar
Bak3rme
Default 5th gear not located where it used to be
2003 350z MT 123k
Issue: my 5th gear over time is not in the location it used to be when i first bought it. i think it shifted about 1/8 inch or less to the left. Before i could push the shifter all the way to the right and up and it would go into gear. Now if i go all the way to right and up to get into 5th its blocked. I can't go all the way to right and up to get into gear, i have to go a tadddd bit to the left from the usual spot.
ALSO,
for reverse i can go all the way right and down to get into reverse WITHOUT pressing the shifter down to get into reverse
any idea?
Old Nov 8, 2015 | 10:40 AM
KornerCarver's Avatar
KornerCarver
It probably isn't a big deal and the mechanism probably needs adjustment. If you don't feel you can do the adjustment, I suggest taking your car to a mechanic or a Nissan dealer to get it fixed.
Old Nov 8, 2015 | 11:03 AM
Emski's Avatar
Emski
https://my350z.com/forum/engine-driv...alignment.html
Old Nov 8, 2015 | 11:17 AM
Spike100's Avatar
Spike100
KornerCarver nails this one. It's probably a simple adjustment. Try that first before you do anything else.
Old Nov 8, 2015 | 05:58 PM
Bak3rme's Avatar
Bak3rme
Thanks @emski
Fixed it and also realized the rubber part was wearing down which was probably causing a weird metal sound when i accelerate around the shifter area.
Old Nov 8, 2015 | 06:04 PM
travlee's Avatar
travlee
Master
good job sir.... glad it worked
350z82
Drag
Nov 9, 2015 10:51 AM
Rouse350z
Nov 5, 2015 11:46 AM
