engine stutter at 3750 rpms (new cold air intake)
Old Nov 30, 2015 | 12:00 PM
kyle.ehinger's Avatar
kyle.ehinger
Default engine stutter at 3750 rpms (new cold air intake)
I recently purchased and installed an injen cold air intake for my 2003 350z. Installation went fine and had no issues. I started it up and again no issues. Took it for a test drive and once I hit 3750rpms it beggins to stutter. Any ideas on what may cause this?
Old Nov 30, 2015 | 12:04 PM
travlee's Avatar
travlee
Master
you have an air leak somewhere, and or you dont have the maf in correctly
Old Nov 30, 2015 | 12:10 PM
kyle.ehinger
Ok thanks i will check all of that stuff thank you
Old Nov 30, 2015 | 12:21 PM
travlee's Avatar
travlee
Master
if it started after you installed it, then something with that is the issue... take it off and do it again
Old Nov 30, 2015 | 01:03 PM
jhc's Avatar
jhc
General & Tech Moderator
^^^ Agree with travlee. Check all the clamps. gl
Old Nov 30, 2015 | 01:39 PM
kyle.ehinger
Doubble checked all my clamps and ensured my maf was in correct and everything was good. It couldnt be an issue with plugs or not enough fuel could it?
Old Nov 30, 2015 | 05:24 PM
Spike100's Avatar
Spike100
I agree with travlee. His suggestion is the most likely cause. Check that first, and then go from there.
Old Dec 1, 2015 | 03:17 PM
zakmartin's Avatar
zakmartin
If all else fails, you might want to try disconnecting the battery before you go to bed, re-connect it in the morning and let the car re-learn its a/f maps using the new part. Since your car is no longer OEM spec, your computer is trying to figure out what's going on and is compensating.
Cux350z
Intake
Dec 11, 2015 03:34 AM
VRed8
Dec 4, 2015 12:13 AM
Whiskers1996
South East Marketplace
Dec 1, 2015 09:13 PM
johnww99
Nov 30, 2015 02:18 PM
Picketttorri
Nov 30, 2015 10:00 AM
