Problem Starting
Old Nov 30, 2015 | 08:19 AM
johnww99's Avatar
johnww99
Default Problem Starting
Hello I'm a new guy here and I need some advice. I have a 2007 350Z HR, 62,000 miles, w/ automatic transmission. Recently I have difficulty starting the motor once it is warmed up. When cold, it starts within a second of turning the ignition but when warmed up it takes several (3-5) attempts to start. The battery is strong, motor turns over rapidly. It almost acts like the motor is not getting spark. Once it does start it runs perfectly.
I have owned the car for three years and this problem just began within the past two months and it's getting progressively worse.
Any thoughts where I should start looking??
Thanks in advance.
Old Nov 30, 2015 | 08:30 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Yes- your Z is equipped with a sophisticated diagnostic system. Pull the codes at a local parts store, or get your own code reader to determine what the problem is. Don't guess and throw parts/solutions at the car.
Old Nov 30, 2015 | 11:25 AM
cincysilvias14's Avatar
cincysilvias14
^what he said. start with codes. my wifes de had the same issue with her body control module not recognizing the key. had a key made and worked fine since. But first time ive heard of a HR having this issue thank god my HR dont
Old Nov 30, 2015 | 12:53 PM
johnww99's Avatar
johnww99
Thanks for the prompt responses. I guess I made a newbie mistake and failed to mention I do not get a CEL status nor have I tried to determine if I can obtain a code reading. Will there be a code if no CEL appears?
Old Nov 30, 2015 | 12:59 PM
cincysilvias14
generally i want to say no but doesnt hurt to do it. plus it's free at autozone
Old Nov 30, 2015 | 02:18 PM
dkmura's Avatar
dkmura
The Nissan diagnostic system will retain codes even if a CEL is not activated. So, yes, you should have a scan done (or even better, get a quality program like UpRev's Cipher so you can do it yourself).
kgman1000
Jul 7, 2020 05:32 PM
Picketttorri
Nov 30, 2015 10:00 AM
hypersonicaz
West Canada
31
Dec 13, 2003 02:51 PM
Stew
Jun 26, 2003 11:22 PM
Z Dreamer
Aug 16, 2002 02:11 AM
