Loud whistle sound after idle air relearn
Old Feb 17, 2016 | 06:08 PM
J_Nunez33's Avatar
J_Nunez33
Unhappy Loud whistle sound after idle air relearn
what's up guys. so i've ran into a issue i can't figure out. My 2003 Z was idling rough so i decided to do a idle relearn and well after the procedure it started to make a very loud whistling sound that it never made until i did the reset. i uninstalled the TB to clean it and installed a new OEM nissan gasket thinking it would fix the problem but nothing. The sound itself seems to be coming around the back of the engine around the throttle body and under the plenum. My Z does have intake mods such has a Z1 5/16 spacer,motordyne iso thermal mod,stillen hi flow intake which never made the noise until now. the car is throwing a pending P0300 for some reason but im not sure if it has anything to do with noise. I have replaced the plugs, cleaned the MAF, and checked all the coils and checked the plugs for a dirty plug but they all look equal. well if anything helps i have a video of the exact noise it makes that i took.
Old Feb 18, 2016 | 09:00 AM
dcains's Avatar
dcains
You've obviously got a vacuum leak somewhere. Especially true if it gets better when you open the throttle, because vacuum drops when you do that.
Old Feb 18, 2016 | 09:06 AM
J_Nunez33's Avatar
J_Nunez33
Thanks bud. I'm guessing it's coming from one of the the gaskets I probably messed with a while back. I'll take apart the plenum and see if that changes anything,kinda sucks it just showed up out of no where.
Old Feb 18, 2016 | 01:43 PM
J_Nunez33's Avatar
J_Nunez33
Found the problem, failed motordyne thermal gasket! Thanks again for the help dcains. Mods please close.
Old Feb 18, 2016 | 09:58 PM
dcains's Avatar
dcains
Happy to help - glad you got it figured out.
Old Feb 19, 2016 | 05:42 AM
jhc's Avatar
jhc
General & Tech Moderator
Glad you got it sorted!
Old Feb 19, 2016 | 01:17 PM
J_Nunez33's Avatar
J_Nunez33
thank you!
Tomci08
May 2, 2016 09:21 AM
hamadanova
Feb 28, 2016 03:00 AM
tjc6591
Feb 10, 2016 03:21 AM
